maybe the key point is how to create user1 and user2 binary. others are just review SDK sample.
Explore... Chat... Share...
#!/usr/bin/python
# -*- coding: cp1252 -*-
# this script will push an OTA update to the ESP
# use it like: python ota_server.py <ESP_IP_address> <sketch.bin>
# NECESARIO PYTHON 2.7
from __future__ import print_function
import socket
import sys
import os
def serve(remoteAddr, filename):
# Parámetros que se pueden cambiar
serverIP = '192.168.1.36'
serverPort = 48266
clientPort = 8266
print('Esperando para la conexion...', file=sys.stderr)
while True:
socket.setdefaulttimeout(1)
sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
server_address = (serverIP, serverPort)
sock.bind(server_address)
sock.listen(1)
sock2 = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
remote_address = (remoteAddr, clientPort)
content_size = os.path.getsize(filename)
message = ' %d %d\n' % ( serverPort, content_size)
sent = sock2.sendto(message, remote_address)
try:
connection, client_address = sock.accept()
print('Conexion establecida', file=sys.stderr)
try:
f = open(filename, "rb")
while True:
chunk = f.read(1460)
if not chunk:
break
sys.stderr.write('.')
sys.stderr.flush()
connection.settimeout(10)
try:
connection.sendall(chunk)
res = connection.recv(4)
except:
print('\nError subiendo firmware', file=sys.stderr)
connection.close()
f.close()
sock.close()
return 1
print('\nEsperando el resultado...\n', file=sys.stderr)
try:
connection.settimeout(60)
data = connection.recv(32)
print('Resultado: %s' % data, file=sys.stderr)
connection.close()
f.close()
sock.close()
return 0
except:
print('Resultado: sin respuesta!', file=sys.stderr)
connection.close()
f.close()
sock.close()
return 1
finally:
connection.close()
f.close()
return 0
except socket.timeout:
sock.close()
sock2.close()
finally:
pass
def main(args):
try:
return serve(args[1], args[2]) #Introduzca como argumentos la IP del Cliente y la direccion del fichero
except:
print('Introduzca como argumentos la IP del Cliente y la direccion del fichero', file=sys.stderr)
print('Ejemplo: python ota_server.py 192.168.1.35 c:\sketch.bin', file=sys.stderr)
return 0
if __name__ == '__main__':
sys.exit(main(sys.argv))#include <ESP8266WiFi.h>
#include <WiFiUDP.h>
const char* ssid = "YourSSID";
const char* password = "YourPass";
const char* host = "192.168.1.35"; //IP del servidor OTA
const uint16_t OTAport = 8266;
//Datos de configuración del módulo IP
IPAddress ip(192,168,1,36);
IPAddress gateway(192,168,1,1);
IPAddress subnet(255, 255, 255, 0);
IPAddress dns(192,168,1,1);
WiFiUDP OTA;
int i = 0; // Contador usado en varios sitios
WiFi.config(ip, gateway, subnet, dns);
WiFi.begin(ssid, password);
Serial.print(".");
delay(200);
OTA.begin(OTAport);
delay(100);
Serial.print("Buscando actualizaciones.");
unsigned long millisNo = millis();
while (millis()-millisNo < 10000){
OTAfirmware();
delay(100); // Este delay es necesario para el OTA, sino no funciona
if (i == 5 ){
Serial.print("."); // Contador y escribo un punto 1 de cada 5 veces
i=0;
else {
i++;
//Your loop
void OTAfirmware() {
if (OTA.parsePacket()) {
IPAddress remote = OTA.remoteIP();
int port = OTA.parseInt();
int size = OTA.parseInt();
Serial.printf("\nActualizando desde la IP: ");
Serial.print(remote);
Serial.printf(", puerto:%d, tamano del fichero:%d\n", port, size);
uint32_t startTime = millis();
WiFiUDP::stopAll();
if(!Update.begin(size)){
Serial.println("Error actualizando");
return;
WiFiClient client;
if (client.connect(remote, port)) {
uint32_t written;
while(!Update.isFinished()){
written = Update.write(client);
if(written > 0) client.print(written, DEC);
Serial.setDebugOutput(false);
if(Update.end()){
client.println("OK");
Serial.printf("Actualizacion completada: %lu\nReiniciando...\n", millis() - startTime);
ESP.restart();
} else {
Update.printError(client);
Update.printError(Serial);
} else {
Serial.printf("Fallo de conexion: %lu\n", millis() - startTime);
}It takes about 20-25 seconds for home assistant c[…]
