By rajbadri
#16552 I am using a esp8266 breakout with a uln2003a to drive a 2 channel opto isolated relay. When i wire it as per the fritzing sketch the esp8266 does not start. only when i remove the jumper wire from gpio 2 pin does the esp8266 boots. if i plug the jumper wire on the gpio 2 pin after the esp8266 had started i can operate the relay perfectly but when i plug the jumper wire before esp8266 has booted the esp won’t start.
guidance needed
Thanks
By j0hncc
#16555 If gpio2 or gpio0 are held low (even "weakly") by external circuit then ESP boots in un-useful mode, I think that is what is happening.
So, try putting a 1k to 4k pull-up resistor from gpio2 to +3.3v
Cheers,
John
By ArnieO
#16564
rajbadri wrote:I am using a esp8266 breakout with a uln2003a to drive a 2 channel opto isolated relay. When i wire it as per the fritzing sketch the esp8266 does not start. only when i remove the jumper wire from gpio 2 pin does the esp8266 boots. if i plug the jumper wire on the gpio 2 pin after the esp8266 had started i can operate the relay perfectly but when i plug the jumper wire before esp8266 has booted the esp won’t start.
guidance needed
Thanks
Is your ULN2003 wired correctly?
