By martinayotte
#26183 The NTPClient.begin() is using a integer for TimeZoneOffset, so your define with 5.5 won't work, except if you change the code to use a "float" instead of a "int".
By jimbob321
#27144 still not updating i can ping it and get a response and if i run ntp client it updates
but the clock example only gets the time on boot.
i have the led now and the time does not drift overnight but no updates.
Code: Select all...WiFi connected
IP address:
192.168.1.110
Received NTP Response
Unix time = 1440630820
No NTP Response :-(
No NTP Response :-(
No NTP Response :-(
No NTP Response :-(
No NTP Response :-(
No NTP Response :-(
No NTP Response :-(
No NTP Response :-(
No NTP Response :-(
By SteveSpencer
#27156 Just one minor issue with the code.
Anyone wanting to use it outside of the PST time zone will, of course, tweak the value from -8.
However, for Europeans, we will also want to change the daylight saving rule, since ours is slightly different from the U.S.A.
It's relatively simple to do, though.
Regards
Steve
