By PaulRB
#23576
Chris Carter wrote:I looked at your github link, it has the NTP and tm1637 libaries, but no example? Am I missing something for this? I'm trying to make a network clock myself so this would be really awesome to help out thanks!
Hi,
The example code is in there. Go into the NTP folder and you will see "Examples/WiFiClock"
Paul
By jimbob321
#25669 i get this in the serial monitor after uploading to a nodemcu board
..WiFi connected
IP address:
192.168.1.110
No NTP Response :-(
the only change i made was to time zone EST-5
but it did the same with PST-8
i dont have the display yet it's on the slowboat.so where can i put a"serial print" to view the time with the serial monitor?
sorry i am a newbee..
By martinayotte
#25682 Did you tried the NTPClient as is from examples folder ?
it should display something like :
Code: Select allsending NTP packet...
packet received, length=48
Seconds since Jan 1 1900 = 3648298174
Unix time = 1439309374
The UTC time is 16:09:34
By jimbob321
#25685
Code: Select all/*************************************************************************
 *  WiFiClock
 *    This program requires the addition of libraries:
 *      NTP
 *      tm1637
 *      Time
 *  Uses the system clock to keep track of time.
 *  A tm1637 module connected to the ESP8266 will display this time.
 *  The time is kept current by hourly requests from an NTP server pool.
 *  WiFi connection
 *    You'll notice that there is no ssid or password hardwired into the code
 *    If the ESP8266 has been previously connected to your network, it will
 *    remember your credentials and use then to reconnect.
 *    If this is the first time this module is to be connected to the network,
 *    this code waits to retrieve your ssid and password over the serial port.
/* You must dedicate two GPIO pins to be used to communicate with the tm1637 module
 * Make sure to connect:
 *   tm1637_clk_pin to the CLK pin on the tm1637 clock module
 *   tm1637_data_pin to the pin on the clock module labeled DIO
  #define tm1637_clk_pin 14
  #define tm1637_data_pin 13
#include <ntp.h>
#include <WiFiUdp.h>
#include <TM1637.h>
#include <Ticker.h>
#include <Time.h>
bool startWiFi(void);
time_t getNTPtime(void);
void readLine(char buffer[], uint8_t size);
void digitalClockDisplay();
void toggleColon(void);
NTP NTPclient;
tm1637 display(tm1637_clk_pin, tm1637_data_pin);
Ticker clock;
bool colon = true;
bool updateTime = true;
#define EST -5 //eastern standard time
  while (!startWiFi()){delay(1500);}
  display.setBrightness(4);
  NTPclient.begin("time.nist.gov", EST);
  setSyncInterval(SECS_PER_HOUR);
  setSyncProvider(getNTPtime);
  clock.attach(0.5, toggleColon);
   if (updateTime){
      updateTime = false;
      if (timeStatus() != timeNotSet)
  return NTPclient.getNtpTime();
  // digital clock display of the time
    display.writeTime(hourFormat12(), minute(), colon);
    colon = !colon;
  uint8_t i;
  //check for persistent wifi connection
 for (i=0;i<10;i++){
   if (WiFi.status() == WL_CONNECTED) return true;
   Serial.print(".");
  /*didn't work: so ask user to enter credentials over Serial Port */
  #define maxSSIDlength 20
  #define maxPASSlength 40
  char ssid[maxSSIDlength];
  char pass[maxPASSlength];
 //prompt the user for his ssid
  Serial.print("Enter ssid name: ");
  readLine(ssid, maxSSIDlength);
  Serial.print("Enter pass phrase: ");
  readLine(pass, maxPASSlength);
  Serial.print("Attempting to Connect");
  if (WiFi.begin(ssid, pass) != WL_CONNECTED) {
     for (i=0;i<10;i++){
       Serial.print(".");
  Serial.print("Failed to connect to: ");
  Serial.println(ssid);
  Serial.print("using pass phrase: ");
  Serial.println(pass);
  return false;
    uint8_t i = 0;
    char c;
    do {
      while (!Serial.available()){yield();} //wait for input
      c = Serial.read();
      Serial.write(c); //echo characters back to user.
      if (c == '\r') break;
      if (c != '\n')
        buffer[i++] = c;
    } while (i < size-1);
    buffer[i] = '\0';
   updateTime = true;
this is what is loaded.^
this is the serial output i have been letting it run to see if it would update. that's the second no response
..WiFi connected
IP address:
192.168.1.110
No NTP Response :-(
No NTP Response :-(
