By JimDrew
#24569 I would like to implement WPS into some client only code. Are there any examples for using the WPS functions (enable/disable/begin/status)? Thanks!
By JimDrew
#24924 Anyone? This is holding up a decision to purchase a significant quantity of these ESP8266EX based modules.
I just need some example code for calling the WPS functions. Thank you!
By kolban
#24925 Howdy Jim,
Please realize that this is a community forum. If your question is gating a commercial purchase of the ESP8266 then I'd suggest formally contacting Espressif at their web site explaining your needs and desires. I am sure that if there is a business opportunity at stake, then they will provide formal product support.
Neil
By kriegste
#24929 Some days ago I found WPS code in the examples. I did not have the opportunity to examine it. So it is untested as far as I'm concerned! Please share your experiences.
Code: Select all/******************************************************************************
 * Copyright 2013-2014 Espressif Systems (Wuxi)
 * FileName: user_main.c
 * Description: entry file of user application
 * Modification history:
 *     2015/7/3, v1.0 create this file.
#include "osapi.h"
#include "user_interface.h"
#include "driver/key.h"
#define WPS_KEY_NUM        1
#define WPS_KEY_IO_MUX     PERIPHS_IO_MUX_MTCK_U
#define WPS_KEY_IO_NUM     13
#define WPS_KEY_IO_FUNC    FUNC_GPIO13
LOCAL struct keys_param keys;
LOCAL struct single_key_param *single_key;
LOCAL void ICACHE_FLASH_ATTR
user_wps_status_cb(int status)
   switch (status) {
      case WPS_CB_ST_SUCCESS:
         wifi_wps_disable();
         wifi_station_connect();
         break;
      case WPS_CB_ST_FAILED:
      case WPS_CB_ST_TIMEOUT:
         wifi_wps_start();
         break;
user_wps_key_short_press(void)
   wifi_wps_disable();
   wifi_wps_enable(WPS_TYPE_PBC);
   wifi_set_wps_cb(user_wps_status_cb);
   wifi_wps_start();
user_rf_pre_init(void)
user_init(void)
   single_key = key_init_single(WPS_KEY_IO_NUM, WPS_KEY_IO_MUX, WPS_KEY_IO_FUNC,
                                          NULL, user_wps_key_short_press);
   keys.key_num = WPS_KEY_NUM;
   keys.single_key = &single_key;
   key_init(&keys);
   wifi_set_opmode(STATION_MODE);
