If you combine the two buffervalues back into an int like I did, you would'n have to bother.
So combining the two bytes into an int:
int value = Wire.read() << 8 | Wire.read(); // combine two bytes into integerExplore... Chat... Share...
int value = Wire.read() << 8 | Wire.read(); // combine two bytes into integer#include <Wire.h>
#define I2CAddressESPWifi 6
void setup()
Serial.begin(9600);
Wire.begin(0,2);
void loop()
Wire.beginTransmission(I2CAddressESPWifi);
Wire.write("Hello Arduino");
Wire.endTransmission();
delay(1);//Required. Not sure why!
Wire.requestFrom(I2CAddressESPWifi,10);
Serial.print("Received from Arduina:[");
while (Wire.available())
delay(1);
char c = Wire.read();
//int error = Wire.endTransmission(); I tried with or without this two lines but still not working
//Serial.print("error: " + error); I tried with or without this two lines but still not working
Serial.print(c);
Serial.println("]");
}#include <Wire.h>
void setup()
Serial.begin(9600);
Wire.begin(I2CAddressESPWifi);
Wire.onReceive(espWifiReceiveEvent);
Wire.onRequest(espWifiRequestEvent);
void loop()
delay(1);
void espWifiReceiveEvent()
Serial.print("Received from ESP [");
Serial.print(c);
void espWifiRequestEvent()
Wire.write("0123456789");
Serial.print("Sending to ESP:[");
Serial.print("0123456789");
}Received from A⸮⸮⸮⸮ٕ⸮⸮from Arduina:[]
Received from ESP [Hello Arduino]
Sending to ESP:[0123456789]
Sending to ESP:[0123456789]It takes about 20-25 seconds for home assistant c[…]
