By Croc
#50608 Thanks. This resolve the problem. Strange that the other version didn't work. I am really happy! I test it on other computer I hope it also work on the other one I always use. THANKS!!!
By rudy
#51118 I have two module programmed with the OTA example, one module that has OTA code (Async web server). The two with the OTA example sketch do not appear as a network device in Ports. I don't know what is wrong. All three devices are listed as online when I check my router. The two that don't show have 4M flash. I have spiffs set 4(3).
I'm running Arduino 1.6.9 and the current stable June 23 ESP8266 code. The three modules are ESP-12E.
Any suggestions?
By rudy
#51134 I have it working now. I don't understand why. I did a re-install of everything and now it works. Same versions I had before. Hopefully it continues to work.
By Vamshi253
#54624 Hi Krzysztof,
First of all thank you for the code.
I am trying your code to implement the OTA functionality on ESP8266 12F module.
But it's a board password while uploading the code wirelessly. I cannot be able to find the password in the code.
Can you help me regarding this.
Regards
Vamshi :-)
