By barti5001
#51532 Hello,
I would like to send my data to databases with my esp8266. Firstly I create database with 3-column table with xampp in localhost, I want save date when the measurement was done,temperature and humidity. In other database I want save date when it was switched and state of device1,device2 etc.
How can I do that?
What should I add to my code?
I partly know MySQL and PHP, but I don't know how I can use them to this project.
It's my code, I can show temperature, humidity and switch on/switch off two leds.
#include "DHT.h"
#define DHTTYPE DHT22   // DHT 21 (AM2301)
// WiFi parameters
const char* ssid = "xxx";
const char* password = "xxx";
// Create an instance of the server
WiFiServer server(80);
// Pin
int device1pin = 5; //d1
int device2pin = 4; //d2
//DHT sensor
const int DHTPin = 14; //d5
// Initialize DHT sensor.
DHT dht(DHTPin, DHTTYPE);
  // Start Serial
  delay(10);
//DHT begin
  dht.begin();
  // Prepare GPIO5
  pinMode(device1pin, OUTPUT);
  pinMode(device2pin, OUTPUT);
  digitalWrite(device1pin, 0);
  digitalWrite(device2pin, 0);
  // Connect to WiFi network
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  // Start the server
  server.begin();
  // Print the IP address
  if (!client) {
    return;
  Serial.println("new client");
  while(!client.available()){
    delay(1);
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  Serial.println(req);
  client.flush();
  // Match the request
  if (req.indexOf("/on2") != -1) {
    digitalWrite(device2pin, 1);
  else if (req.indexOf("/off2") != -1) {
  if (req.indexOf("/on1") != -1){
    digitalWrite(device1pin, 1);
  else if (req.indexOf("/off1") != -1) {
    client.flush();
  // Prepare the response
  client.println( "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n");
  client.println( "<head>");
  client.println( "<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
  client.println( "<script src=\"https://code.jquery.com/jquery-2.1.3.min.js\"></script>");
  client.println( "<link rel=\"stylesheet\" href=\"https://maxcdn.bootstrapcdn.com/bootstrap/3.3.4/css/bootstrap.min.css\">");
  client.println( "</head>");
  client.println( "<div class=\"container\">");
  client.println("<h1>Temperature: ");
  client.println(t);
  client.println( "</h1>");
  client.println( "<h1>Humidity: ");
  client.println(h);
  client.println("</h1>");
  String s = "<h1>Relay Control</h1>";
  s += "<div class=\"row\">";
  s += "<div class=\"col-md-2\"><input id=\"divinput1\" class=\"btn btn-block btn-lg btn-primary\" type=\"button\" value=\"On1\" onclick=\"on1()\"></div>";
  s += "<div class=\"col-md-2\"><input class=\"btn btn-block btn-lg btn-danger\" type=\"button\" value=\"Off1\" onclick=\"off1()\"></div>";
  s += "<div class='col-md-2'><div id='value1'>Brak inf</div></div>";
  s += "</div>";
  s += "<br />";
  s += "<div class=\"col-md-2\"><input class=\"btn btn-block btn-lg btn-primary\" type=\"button\" value=\"On2\" onclick=\"on2()\"></div>";
  s += "<div class=\"col-md-2\"><input class=\"btn btn-block btn-lg btn-danger\" type=\"button\" value=\"Off2\" onclick=\"off2()\"></div>";
  s += "<div class=\"col-md-2\"><div id=\"value2\">Brak inf</div></div>";
  s += "</div></div>";
  s += "<script>function on1() {$.get('on1');$(\"#value1\").text(\"Device1 is on\");}</script>";
  s += "<script>function off1() {$.get(\"/off1\");$(\"#value1\").text(\"Device1 is off\");}</script>";
  s += "<script>function on2() {$.get('on2');$(\"#value2\").text(\"Device2 is on\");}</script>";
  s += "<script>function off2() {$.get(\"/off2\");$(\"#value2\").text(\"Device2 is off\");}</script>";
  client.print(s);
  delay(1);
  Serial.println("Client disconnected");
  // The client will actually be disconnected
  // when the function returns and 'client' object is detroyed
By villTech
#51548 1. create php file that receive POST request and save it to mysql database.
2. have esp POST your variables to the php file you created
By barti5001
#51581
villTech wrote:1. create php file that receive POST request and save it to mysql database.
Thank you for your answer.
But how can I have post variables to the php file with esp8266 code? And where should I place this php file?
By villTech
#51595 sample arduino esp POST request to server php file:
Code: Select all    h = dht.readHumidity();
    String postStr = "humi=" + h + "&temp=" + t;
    client.print(String("POST ") + "/yourPHPfile.php HTTP/1.1\r\n" +
               "Host: <yorServerIP>\r\n" +
               "Content-Type: application/x-www-form-urlencoded\r\n" +
               "Connection: keep-alive\r\n" +
               "Content-Length: " + postStr.length() + "\r\n\r\n" + postStr);
barti5001 wrote: Firstly I create database with 3-column table with xampp in localhost.
i assumed you set up your xampp on a pc. then php should be and running in your pc.
you can use php date() function to get a timestamp every POST request
