By erhardd
#32405 I've tried it to copy/paste my working Ucglib to an other laptop:
To make it short, it did not work ! :(
I've changed in Ucglib.h:
Code: Select all#include "C:\Dokumente und Einstellungen\ich\Eigene Dateien\Downloads\ucglib-master\ucglib-master\csrc/utility/ucg.h"
to fit my directories, but nothing.
Most probably you have, nevertheless, the way which I has described before to go.
There exists there probably linker- dependence which must be compiled ..
By erhardd
#32481 If you are not able to build it with cygwin and you only want to see your display working:
first: -it's not the ucglib;
- you have to open TFTv2.h and to change line 187-190 to your Pins CS and DC.
BL is at 3.3V
RST at rst - esp;
SPI-Pins;
No touch !
Take the text.ino;
7z is free and powerfull (google) ..
