Hi, martin, and thanks for your suggestion - should have thought of it
I just changed the code to dump the the contents of each buffer read as you suggested. Here is the new loop:
Code: Select all while (client.available()) {
int bytesRead = client.readBytes(buffer, sizeof(buffer));
Serial.println("==========");
Serial.print(bytesRead);
Serial.println(" bytes read:");
Serial.write((const char*)buffer, bytesRead);
browserClient.write((const char*)buffer, bytesRead);
Serial.println("Response sent");
The result is that the beginning of the page is read and returned but then it stops in the middle (the full dump is below). It's strange that it doesn't stop on a buffer boundary, and it always stops at the same position, (except when their nginx proxy replies, which causes a different web page to be returned).
I also tried disabling the last line of the loop (which returns the buffer back to the browser) so that the webpage is only dumped on serial, but it stops at the exact same place.
Looks like the connection to the server is interrupted somehow, but I really don't understand why...
Any idea ?
Thanks.
Vicne
PS: Dump:
Code: Select allServing request
Request is GET / HTTP/1.1
Connecting to remote server
connected
Request sent
Client available
1024 bytes read:
HTTP/1.1 200 OK
Server: Apache
Vary: Host
X-App-Name: homepage
Cache-Control: no-cache
Content-Type: text/html; charset=utf-8
Transfer-Encoding: chunked
Date: Tue, 31 May 2016 21:57:09 GMT
X-API-Version: 5-5
X-Cache: hit
X-PageType: homepage
Connection: close
X-Frame-Options: DENY
Set-Cookie: RMID=007f010154a0574e08b50007;Path=/; Domain=.nytimes.com;Expires=Wed, 31 May 2017 21:57:09 UTC;NYT-wpAB=0089|0;Path=/; Domain=.nytimes.com;Expires=Wed, 01 Jun 2016 21:57:09 UTC
X-Exp-H: 0
002c4c
<!DOCTYPE html>
<!--[if (gt IE 9)|!(IE)]> <!--> <html lang="en" class="no-js edition-domestic app-homepage" itemscope xmlns:og="http://opengraphprotocol.org/schema/"> <!--<![endif]-->
<!--[if IE 9]> <html lang="en" class="no-js ie9 lt-ie10 edition-domestic app-homepage" xmlns:og="http://opengraphprotocol.org/schema/"> <![endif]-->
<!--[if IE 8]> <html lang="en" class="no-js ie8 lt-ie10 lt-ie9 edition-domestic app-homepage" xmlns:og="http://opengraphprotocol.org/schema/"> <![endif]-->
<!--[if (lt IE
1024 bytes read:
8)]> <html lang="en" class="no-js lt-ie10 lt-ie9 lt-ie8 edition-domestic app-homepage" xmlns:og="http://opengraphprotocol.org/schema/"> <![endif]-->
<head>
<title>The New York Times - Breaking News, World News & Multimedia</title>
<meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1" /><script type="text/javascript">window.NREUM||(NREUM={}),__nr_require=function(e,t,n){function r(n){if(!t[n]){var o=t[n]={exports:{}};e[n][0].call(o.exports,function(t){var o=e[n][1][t];return r(o||t)},o,o.exports)}return t[n].exports}if("function"==typeof __nr_require)return __nr_require;for(var o=0;o<n.length;o++)r(n[o]);return r}({1:[function(e,t,n){function r(e,t){return function(){o(e,[(new Date).getTime()].concat(a(arguments)),null,t)}}var o=e("handle"),i=e(2),a=e(3);"undefined"==typeof window.newrelic&&(newrelic=NREUM);var u=["setPageViewName","addPageAction","setCustomAttribute","finished","addToTrace","inlineHit"],c=["addPageAction"],f="api-";i(u,function(e,t){newrelic[t]=r(f+t,"api")}),i(c,function(
1024 bytes read:
e,t){newrelic[t]=r(f+t)}),t.exports=newrelic,newrelic.noticeError=function(e){"string"==typeof e&&(e=new Error(e)),o("err",[e,(new Date).getTime()])}},{}],2:[function(e,t,n){function r(e,t){var n=[],r="",i=0;for(r in e)o.call(e,r)&&(n[i]=t(r,e[r]),i+=1);return n}var o=Object.prototype.hasOwnProperty;t.exports=r},{}],3:[function(e,t,n){function r(e,t,n){t||(t=0),"undefined"==typeof n&&(n=e?e.length:0);for(var r=-1,o=n-t||0,i=Array(0>o?0:o);++r<o;)i[r]=e[t+r];return i}t.exports=r},{}],ee:[function(e,t,n){function r(){}function o(e){function t(e){return e&&e instanceof r?e:e?u(e,a,i):i()}function n(n,r,o){e&&e(n,r,o);for(var i=t(o),a=l(n),u=a.length,c=0;u>c;c++)a[c].apply(i,r);var s=f[g[n]];return s&&s.push([m,n,r,i]),i}function p(e,t){w[e]=l(e).concat(t)}function l(e){return w[e]||[]}function d(e){return s[e]=s[e]||o(n)}function v(e,t){c(e,function(e,n){t=t||"feature",g[n]=t,t in f||(f[t]=[])})}var w={},g={},m={on:p,emit:n,get:d,listeners:l,context:t,buffer:v};return m}function i(){return new r}var a="nr@contex
1024 bytes read:
t",u=e("gos"),c=e(2),f={},s={},p=t.exports=o();p.backlog=f},{}],gos:[function(e,t,n){function r(e,t,n){if(o.call(e,t))return e[t];var r=n();if(Object.defineProperty&&Object.keys)try{return Object.defineProperty(e,t,{value:r,writable:!0,enumerable:!1}),r}catch(i){}return e[t]=r,r}var o=Object.prototype.hasOwnProperty;t.exports=r},{}],handle:[function(e,t,n){function r(e,t,n,r){o.buffer([e],r),o.emit(e,t,n)}var o=e("ee").get("handle");t.exports=r,r.ee=o},{}],id:[function(e,t,n){function r(e){var t=typeof e;return!e||"object"!==t&&"function"!==t?-1:e===window?0:a(e,i,function(){return o++})}var o=1,i="nr@id",a=e("gos");t.exports=r},{}],loader:[function(e,t,n){function r(){if(!w++){var e=v.info=NREUM.info,t=s.getElementsByTagName("script")[0];if(e&&e.licenseKey&&e.applicationID&&t){c(l,function(t,n){e[t]||(e[t]=n)});var n="https"===p.split(":")[0]||e.sslForHttp;v.proto=n?"https://":"http://",u("mark",["onload",a()],null,"api");var r=s.createElement("script");r.src=v.proto+e.agent,t.parentNode.insertBefore(r,t)}}}
1024 bytes read:
function o(){"complete"===s.readyState&&i()}function i(){u("mark",["domContent",a()],null,"api")}function a(){return(new Date).getTime()}var u=e("handle"),c=e(2),f=window,s=f.document;NREUM.o={ST:setTimeout,CT:clearTimeout,XHR:f.XMLHttpRequest,REQ:f.Request,EV:f.Event,PR:f.Promise,MO:f.MutationObserver},e(1);var p=""+location,l={beacon:"bam.nr-data.net",errorBeacon:"bam.nr-data.net",agent:"js-agent.newrelic.com/nr-918.min.js"},d=window.XMLHttpRequest&&XMLHttpRequest.prototype&&XMLHttpRequest.prototype.addEventListener&&!/CriOS/.test(navigator.userAgent),v=t.exports={offset:a(),origin:p,features:{},xhrWrappable:d};s.addEventListener?(s.addEventListener("DOMContentLoaded",i,!1),f.addEventListener("load",r,!1)):(s.attachEvent("onreadystatechange",o),f.attachEvent("onload",r)),u("mark",["firstbyte",a()],null,"api");var w=0},{}]},{},["loader"]);</script>
<link rel="shortcut icon" href="https://static01.nyt.com/favicon.ico" />
<link rel="apple-touch-icon-precomposed" sizes="144×144" href="https://static01.nyt.com/
720 bytes read:
images/icons/ios-ipad-144x144.png" />
<link rel="apple-touch-icon-precomposed" sizes="114×114" href="https://static01.nyt.com/images/icons/ios-iphone-114x144.png" />
<link rel="apple-touch-icon-precomposed" href="https://static01.nyt.com/images/icons/ios-default-homescreen-57x57.png" />
<meta name="sourceApp" content="nyt-v5" />
<meta id="applicationName" name="applicationName" content="homepage" />
<meta id="foundation-build-id" name="foundation-build-id" content="" />
<link rel="canonical" href="http://www.nytimes.com" />
<link rel="alternate" type="application/rss+xml" title="RSS" href="http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" />
<link rel="alternate" media="only screen and (max-width: 640pResponse sent
BrowserClient served
