By F. Goncalves
#47874 Hi,
I want to have ans ESP8266 working as an client and also as an server. I made this code and it works good until I try to send an code the the client or open its web page. After that it gets unresponsive.
You see any problem in this code?
  if (!client) {
    return;
  // Wait until the client sends some data
  Serial.println("new client");
  String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html><HEAD><TITLE>WEB SITE</TITLE> </HEAD>";
  s += "<BODY><H1>WEB SITE ESP8266 SYSTEM</H1>";
  s += "</b><br>Current ON Time: ";
  s += millis() * 0.000016667;
  s += " min";
  s += "<br>";
  s += "</BODY>";
  s += "</html>\n";
  client.print(s);
  while (!client.available()) {
    delay(1);
  Serial.println(req);
  client.flush();
  // Match the request
  if (req.indexOf("relay1_ON") != -1) {
    Relay1Status = 1;
    digitalWrite(Relay1, 0);
  if (req.indexOf("relay1_OFF") != -1) {
    Relay1Status = 0;
    digitalWrite(Relay1, 1);
   else {
    Serial.println("invalid request");
    client.stop();
    return;
  client.flush();
  // Prepare the response
  String s2 = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\n Command Done ";
  s2 += "</html>\n";
  client.print(s2);
  delay(1);
  Serial.println("Client disconnected");
