By turti
#58218 Hello there!
I have got an Arduino UNO with an Ethernet Shield (W5100) with the following code, to read data out of my PLC
Code: Select all#include <SPI.h>
#include <Ethernet.h>
#include "Settimino.h"
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //MAC
IPAddress ip(192,168,127,14); // Local Address
IPAddress PLC(192,168,127,110);   // PLC Address
S7Client Client;
void setup()
    Serial.begin(9600);
     while (!Serial) {
      ; // wait for serial port to connect. Needed for Leonardo only
    // Start the Ethernet Library
    Ethernet.begin(mac, ip);
    delay(200);
    Serial.println(Ethernet.localIP());
bool Connect()
    int Result=Client.ConnectTo(PLC,
                                  0,  // Rack (see the doc.)
                                  0); // Slot (see the doc.)
    Serial.print("Connecting to ");Serial.println(PLC);
    if (Result==0)
      Serial.print("Connected ! PDU Length = ");
      Serial.println(Client.GetPDULength());
      Serial.println("Connection error");
    return Result==0;
void CheckError(int ErrNo)
  Serial.print("Error No. 0x");
  Serial.println(ErrNo, HEX);
  // Checks if it's a Severe Error => we need to disconnect
  if (ErrNo & 0x00FF)
    Serial.println("SEVERE ERROR, disconnecting.");
    Client.Disconnect();
byte Empfangen(int Zeile)     //einzelne Bytes empfangen
  int Result;
  byte Receive;
  // Verbinden
  while (!Client.Connected)
    if (!Connect())
  Result=Client.ReadArea(S7AreaDB, //DB Zugriff
                         53,        // DB Number = 53
                         Zeile,        // Start ab Byte x
                         1,     // Anzahl der Bytes
                         &Receive);  // Ziel
  if (Result==0)
    return Receive;
    CheckError(Result);
void loop()
  Serial.print("Daten aus SPS: ");
  Serial.println(Empfangen(20));   //Lese Byte aus DB Zeile 20
  Serial.println("");
This works fine!
Now I want to try it on my ESP8266 (WittyBoard), so I changed the code at the top to its new environment:
char* ssid     = "myWIFI";
char* password = "myPassword";
IPAddress gateway(192,168,127,1);
IPAddress subnet(255,255,255,0);
S7Client Client;
void setup()
     while (!Serial) {
    // Start the WiFi Library
    WiFi.mode(WIFI_AP_STA);
    WiFi.config(ip, gateway, subnet);
    WiFi.begin(ssid, password);
      Serial.print(".");
    Serial.println("");
bool Connect()
    if (Result==0)
    return Result==0;
  if (ErrNo & 0x00FF)
  int Result;
  byte Receive;
  // Verbinden
    if (!Connect())
                         &Receive);  // Ziel
  if (Result==0)
    return Receive;
    CheckError(Result);
void loop()
  Serial.println("");
... but that don´t work. Examples like the webserver are working fine on it - no hardware problem.
What could be the problem? :?:
