I tried wifi multi, but because you have to use delay() to give it some time to connect, i never managed to get it under 4 seconds, most of the time it was 5, and that doesn't even include actually getting an IP etc; just authenticating with the AP.
#include <ESP8266WiFiMulti.h>
ESP8266WiFiMulti wifiMulti;
void setup()
WiFi.mode(WIFI_STA);
wifiMulti.addAP("AP_ONE", "password1");
wifiMulti.addAP("AP_TWO", "password2");
unsigned long start_time = millis();
while (wifiMulti.run() != WL_CONNECTED)
delay(50);
unsigned long end_time = millis();
unsigned long elapsed_time = end_time - start_time;
Serial.print("start: "); Serial.println(start_time);
Serial.print("end: "); Serial.println(end_time);
Serial.print("elapsed: "); Serial.println(elapsed_time);
Serial.print("Connection status: "); Serial.println(WiFi.status());
WiFi.printDiag(Serial);
void loop()
The problem is the
return codes don't work, you only ever get a 3 or 6, i'm sure if 1 (WL_NO_SSID_AVAIL) worked it would be almost instant.
