By 78987
#78314 Which Arduino ESP8266 mesh library is the most power-effective? I am running from battery, so power consumption is a big issue. My mesh also needs to connect to an Android hotspot and communicate with an app running on the Android device. The application is also time-critical, so latency should be as low as possible.
