Page 2 of 4
Re: Example of featured sketch wanted
PostPosted: Mon Oct 08, 2018 3:15 am
by grhhm
rudy wrote:Have you looked at https://github.com/philbowles/esparto and https://github.com/marvinroger/homie-esp8266?
Not heard about these. Thanks for the pointers. I checked them out.
Esparto seems to use "own language" to make the ESP functional. This looks kind of easyEsp.
Homie looks pretty versatile framework which implements all I wanted. I managed to install the lib, compile sample project, upload it and check it. Now I am carefully checking all the implemented features for stability and performance.
Thank you for the hint again.
PostPosted: Wed Oct 10, 2018 1:35 pm
by grhhm
Hi rudy,
This looks like your instructables :)
It looks you managed well with Homie. I have troubles with everything related to MQTT:
The messages from Homie to Broker go well. However from broker to Homie nothing arrives. This makes impossible control and OTA via MQTT.
I posted question and debug info in github issues: https://github.com/marvinroger/homie-es ... -428110033
No response yet.
Maybe could you share your Homie sketch which is able to OTA and control GPIO via MQTT?
Thank you.
PostPosted: Wed Oct 10, 2018 6:51 pm
by rudy
That instructable isn't from me. I have never used Homie. I looked at it and it looks promising. It has lots of stars. I have used async-mqtt-client https://github.com/marvinroger/async-mqtt-client produced by the same individual and it seemed to work well. Homie is a lot more, a framework.
It seemed to have the things you asked for so I suggested it.
PostPosted: Thu Oct 11, 2018 2:06 am
by grhhm
Thank you rudy.
A part of my problem solved: I was defining in configuration an own base name. When I reset the configuration and leave the base name empty it becomes 'homie' and OTA works. Now I just need to understand how to make homie accepting messages for variable setting (e.g. light on/off).
