Page 1 of 2
Spiffs not supported on ESP8266
PostPosted: Wed Mar 06, 2019 5:33 pm
by Osvaldo
Hi, I am new with ESP8266 but not with Arduino. I am starting to use Arduino IDE to program webservers with my ESP8266 nodemcu V3 lollin.
I read about SPIFF option as a good way, so I installed the tool for sketch data upload in the IDE, which is done.
The problem is that when I try to use this, I get the error message "SPIFFS not Supported on ESP8266".
I have the board defined as NodeMCU 1.0 (ESP 12E Module) as the Lollin site says.
Try IDE 1.8.6, and 1.8.8 with the same answer.
I can not find the solution on the network for this.
In the other hand, I can use other options to get a similar result from my webservers but I would like to resolve this, at least to get the knowhow.
Does anyone have an idea of how to solve this issue?
Regards
Osvaldo
Re: Spiffs not supported on ESP8266
PostPosted: Mon Mar 11, 2019 9:17 pm
by Osvaldo
Well as I imagined from the beginning, something was wrong. Indeed, the jar file that I was trying to use corresponded to esp32 and not to esp8266. Fixed this, already everything works.
My apologies .
PostPosted: Fri Sep 25, 2020 10:48 am
by W9SPY
I'm having the same problem as you described. Can you help me locate the files that I need to correct the problem? Thank you.
Update: While waiting for this post to be approved, I solved the problem on my own. (Basically, it was a matter of me not having all of the wiring properly in place).
PostPosted: Wed Sep 30, 2020 9:32 am
by mrburnette
SPIFFs project to implement the entire OUI database as l lookup table:
https://www.hackster.io/rayburne/oui-oui-spiffy-spiffs-on-esp8266-323ae4
