By labeutte
#82244 hello,
I developed an esp8266 application (c ++) with API arduino. It works fine when I upload it.
How to burn it in the ESP for it starts at boot ?
thanks for answers.
By QuickFix
#82262 Just make sure GPIO15 is pulled LOW and GPIO0 (and GPIO2) are pulled HIGH (both using resistors). :idea:
If you're using a NodeMCU or a Wemos (or any other development board), it should run without any alterations or special switch settings.
