By Carlitos007
#83082 Hi All!
finally had sometime to attack this project.
it consisted on gathering data from a Pot (analog Read on the NodeMcu), passing the data to a webpage, and then displaying the data on the gauge.
It Works!!!
Here are the main parts of the Sketch: Ino
Code: Select all* Wifi-AP MODE
 * 07/11/2019
#include <ESP8266WebServer.h>
#include <FS.h>   //Include File System Headers
const char* htmlfile = "/index.html";
          //WiFi Connection configuration
const char *ssid = "My Wifi";
const char *password = "123456789";
  ESP8266WebServer server(80);
void handleADC(){
  int a = analogRead(A0);
  a = map(a,0,1023,0,100);
  String adc = String(a);
  Serial.println(adc);
  server.send(200, "text/plane",adc); //sends data to server
void handleRoot(){
  server.sendHeader("Location", "/index.html",true);   //Redirect to our html web page
  server.send(302, "text/plane","");
void handleWebRequests(){
  if(loadFromSpiffs(server.uri())) return;
  String message = "File Not Detected\n\n";
  message += "URI: ";
  message += server.uri();
  message += "\nMethod: ";
  message += (server.method() == HTTP_GET)?"GET":"POST";
  message += "\nArguments: ";
  message += server.args();
  message += "\n";
  for (uint8_t i=0; i<server.args(); i++){
    message += " NAME:"+server.argName(i) + "\n VALUE:" + server.arg(i) + "\n";
  server.send(404, "text/plain", message);
  Serial.println(message);
  delay(1000);
             //Initialize File System
  SPIFFS.begin();
  Serial.println("File System Initialized");
  Serial.print("Setting AP (Access Point)…");
             //Connect to wifi Network
  WiFi.mode(WIFI_AP);           //Only Access point
  WiFi.softAP(ssid, password);   //Start HOTspot
      //If connection successful show IP address in serial monitor
  Serial.print("Connected to: ");
  Serial.println(ssid);
  IPAddress IP = WiFi.softAPIP();
  Serial.print("Server IP address: ");
  Serial.println(IP);
              //Initialize Webserver
  server.on("/",handleRoot);
  server.on("/getADC",handleADC); //Reads ADC function is called from out index.html
  server.onNotFound(handleWebRequests); //Set setver all paths are not found so we can handle as per URI
  server.begin();
 server.handleClient();
bool loadFromSpiffs(String path){
  String dataType = "text/plain";
  if(path.endsWith("/")) path += "index.htm";
  if(path.endsWith(".src")) path = path.substring(0, path.lastIndexOf("."));
  else if(path.endsWith(".html")) dataType = "text/html";
  else if(path.endsWith(".htm")) dataType = "text/html";
  else if(path.endsWith(".css")) dataType = "text/css";
  else if(path.endsWith(".js")) dataType = "application/javascript";
  else if(path.endsWith(".png")) dataType = "image/png";
  else if(path.endsWith(".gif")) dataType = "image/gif";
  else if(path.endsWith(".jpg")) dataType = "image/jpeg";
  else if(path.endsWith(".ico")) dataType = "image/x-icon";
  else if(path.endsWith(".xml")) dataType = "text/xml";
  else if(path.endsWith(".pdf")) dataType = "application/pdf";
  else if(path.endsWith(".zip")) dataType = "application/zip";
  File dataFile = SPIFFS.open(path.c_str(), "r");
  if (server.hasArg("download")) dataType = "application/octet-stream";
  if (server.streamFile(dataFile, dataType) != dataFile.size()) {
  dataFile.close();
  return true;
Here is the Index.html:
Code: Select all<!doctype html>
<html>
<head>
    <title>Testing Gauges</title>
    <script src="gauge.min.js"></script>
    <link rel="stylesheet" type="text/css" href="gauge.css">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
</head>
<body>
<header>
<h1>Testing Gauge </h1>
</header>
<div align="center">
<canvas id="gauge-ps"></canvas>
</div>
<script>
     setInterval(function() {
     GetADC();
   }, 1000);
function GetADC() {
var xhttp = new XMLHttpRequest();
          var adc=0;
     xhttp.onreadystatechange = function() {
       if (this.readyState == 4 && this.status == 200) {
          adc = Number(this.responseText);
        //adc = this.responseText ;
      document.getElementById("demo").innerHTML = adc;
       gaugePS.value = adc;  //send DATA to needle
     xhttp.open("GET", "/getADC", true);
     xhttp.send();
    var gaugePS = new RadialGauge({
    renderTo: 'gauge-ps',
    width: 200,
    height: 200,
    units: "°F",
    title: "Analog",
    minValue: 60,
    maxValue: 260,
    majorTicks: [60,80,100,120,140,160,180,200,240,260],
    minorTicks: 2,
    strokeTicks: true,
    highlights: [
            "from": 60,
            "to": 100,
            "color": "rgba(0,0, 255, .3)"
            "from": 190,
            "to": 260,
            "color": "rgba(255, 0, 0, .3)"
    ticksAngle: 225,
    startAngle: 67.5,
    colorMajorTicks: "#ddd",
    colorMinorTicks: "#ddd",
    colorTitle: "#eee",
    colorUnits: "#ccc",
    colorNumbers: "#eee",
    colorPlate: "#222",
    borderShadowWidth: 0,
    borders: true,
    needleType: "arrow",
    needleWidth: 2,
    needleCircleSize: 7,
    needleCircleOuter: true,
    needleCircleInner: false,
    animationDuration: 1500,
    animationRule: "linear",
    colorBorderOuter: "#333",
    colorBorderOuterEnd: "#111",
    colorBorderMiddle: "#222",
    colorBorderMiddleEnd: "#111",
    colorBorderInner: "#111",
    colorBorderInnerEnd: "#333",
    colorNeedleShadowDown: "#333",
    colorNeedleCircleOuter: "#333",
    colorNeedleCircleOuterEnd: "#111",
    colorNeedleCircleInner: "#111",
    colorNeedleCircleInnerEnd: "#222",
    valueBoxBorderRadius: 0,
    colorValueBoxRect: "#222",
    colorValueBoxRectEnd: "#333"
gaugePS.draw();
</script>
<p id="demo"></p>
</body>
</html>
Look at the attached picture to see what it looks like and it does move the needle every time the pot is moved to a different position!
By Carlitos007
#83085 With that Done, Now I would like to actually get data from a Sensor that uses RS485 instead of Analog read.
Problem: the sensor gives out a response of multiple bytes exp; 01 03 08 00 64 00 3E 00 0D 00 55 9C E8.
so, if I used the following to read and send it to the server as a string of one byte of Data from the analog read:
INO file
void handleADC(){
How would be a good practice to send all 01 03 08 00 64 00 3E 00 0D 00 55 9C E8 as a string or array to the server? also keep in mind how would the server assemble this data or save to be used later. par-say each byte is a reading for each gauge. like It was used here:
HTML.file
<script>
GetADC();
}, 1000);
function GetADC() {
var adc=0;
xhttp.send();
By Carlitos007
#83086
josephchrzempiec wrote:Hello i very much like this and try this. But i wonder if it is possible you can include the CSS and JS files for the html page please?
Joseph
here is the JS. file :
Code: Select all/*!
 * The MIT License (MIT)
 * Copyright (c) 2016 Mykhailo Stadnyk <mikhus@gmail.com>
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
 * SOFTWARE.
 * @version 2.1.5
!function(e){"use strict";function t(e,t){if(!e)throw new ReferenceError("this hasn't been initialised - super() hasn't been called");return!t||"object"!=typeof t&&"function"!=typeof t?e:t}function i(e,t){if("function"!=typeof t&&null!==t)throw new TypeError("Super expression must either be null or a function, not "+typeof t);e.prototype=Object.create(t&&t.prototype,{constructor:{value:e,enumerable:!1,writable:!0,configurable:!0}}),t&&(Object.setPrototypeOf?Object.setPrototypeOf(e,t):e.__proto__=t)}function r(e,t){if(!(e instanceof t))throw new TypeError("Cannot call a class as a function")}function o(e,t){if(t||(t="undefined"==typeof window?global:window),void 0!==t[e])return t[e];for(var i=["webkit","moz","ms","o"],r=0,o=i.length,n=e.charAt(0).toUpperCase()+e.substr(1);r<o;r++){var a=t[i[r]+n];if(void 0!==a)return a}return null}function n(e,t,i,r,o,a,l){if("function"!=typeof r)throw new TypeError("Invalid animation rule:",r);var s=e-i,d=s/o,u=0;d>1&&(d=1),1!==d&&(u=r(d),isFinite(u)&&!isNaN(u)&&(d=u)),t&&t(d),s<o?l.frame=G(function(e){return n(e,t,i,r,o,a,l)}):(a&&a(),l.inProgress=!1)}function a(){Array.prototype.constructor.apply(this,arguments)}function l(e){if(!(e instanceof DOMException&&2152923147===e.result))throw e}function s(e){return e.majorTicks instanceof Array||(e.majorTicks=e.majorTicks?[e.majorTicks]:[]),e.majorTicks.length||(e.majorTicks.push(K.formatMajorTickNumber(e.minValue,e)),e.majorTicks.push(K.formatMajorTickNumber(e.maxValue,e))),["right"!==e.tickSide,"left"!==e.tickSide]}function d(e,t,i,r,o,n){e.beginPath(),e.moveTo(t+n,i),e.lineTo(t+r-n,i),e.quadraticCurveTo(t+r,i,t+r,i+n),e.lineTo(t+r,i+o-n),e.quadraticCurveTo(t+r,i+o,t+r-n,i+o),e.lineTo(t+n,i+o),e.quadraticCurveTo(t,i+o,t,i+o-n),e.lineTo(t,i+n),e.quadraticCurveTo(t,i,t+n,i),e.closePath()}function u(e,t){var i=t.valueDec,r=t.valueInt,o=0,n=void 0,a=void 0,l=void 0;if(e=parseFloat(e),l=e<0,e=Math.abs(e),i>0){for(a=e.toFixed(i).toString().split("."),n=r-a[0].length;o<n;++o)a[0]="0"+a[0];a=(l?"-":"")+a[0]+"."+a[1]}else{for(a=Math.round(e).toString(),n=r-a.length;o<n;++o)a="0"+a;a=(l?"-":"")+a}return a}function c(e,t){var i=void 0,r=!1;return i=0===t.majorTicksDec?Math.round(e).toString():e.toFixed(t.majorTicksDec),t.majorTicksInt>1?(r=~i.indexOf("."),~i.indexOf("-")?"-"+[t.majorTicksInt+t.majorTicksDec+2+(r?1:0)-i.length].join("0")+i.replace("-",""):[t.majorTicksInt+t.majorTicksDec+1+(r?1:0)-i.length].join("0")+i):i}function h(e){return e*Math.PI/180}function f(e,t){return{x:-e*Math.sin(t),y:e*Math.cos(t)}}function v(e,t,i,r){var o=!(arguments.length>4&&void 0!==arguments[4])||arguments[4],n=arguments.length>5&&void 0!==arguments[5]?arguments[5]:0,a=e.createLinearGradient(o?0:n,o?n:0,o?0:r,o?r:0);return a.addColorStop(0,t),a.addColorStop(1,i),a}function m(e,t){if(arguments.length>2&&void 0!==arguments[2]&&arguments[2])return e.restore(),!0;e.save();var i=t.borderShadowWidth;return i&&(e.shadowBlur=i,e.shadowColor=t.colorBorderShadow),!0}function p(e,t){t.needleShadow&&(e.shadowOffsetX=2,e.shadowOffsetY=2,e.shadowBlur=10,e.shadowColor=t.colorNeedleShadowDown)}function g(e,t,i){return e["font"+t+"Style"]+" "+e["font"+t+"Weight"]+" "+e["font"+t+"Size"]*i+"px "+e["font"+t]}function w(e){e.shadowOffsetX=null,e.shadowOffsetY=null,e.shadowBlur=null,e.shadowColor="",e.strokeStyle=null,e.lineWidth=0,e.save()}function b(e,t,i,r){t.valueTextShadow&&(e.shadowOffsetX=i,e.shadowOffsetY=i,e.shadowBlur=r,e.shadowColor=t.colorValueTextShadow)}function y(e,t,i,r,o,n){if(t.valueBox){w(e);var a=t.valueDec?1+t.valueDec:0,l="9".repeat(Math.max.apply(null,[String(parseInt(i)).length+a].concat(t.majorTicks.map(function(e){return String(parseInt(e,10)).length+a})))),s=t.valueText||u(i,t),c=n/200,h=n/100,f=.4*h,v=1.2*h;e.font=g(t,"Value",c),b(e,t,f,v);var m=e.measureText(t.valueText?s:"-"+u(Number(l),t)).width;w(e);var p=parseFloat(t.fontValueSize)*c+f+v,y=h*parseFloat(t.valueBoxStroke),x=2*n-2*y,k=m+10*h,T=1.1*p+f+v,S=h*t.valueBoxBorderRadius,O=(parseFloat(t.valueBoxWidth)||0)/100*x;O>k&&(k=O),k>x&&(k=x);var A=r-k/2,C=o-T/2,V=o-5.75*h;if(e.beginPath(),S?d(e,A,C,k,T,S):e.rect(A,C,k,T),y){var N=e.createRadialGradient(r,V,10*h,r,V,20*h);N.addColorStop(0,t.colorValueBoxRect),N.addColorStop(1,t.colorValueBoxRectEnd),e.strokeStyle=N,e.lineWidth=y,e.stroke()}t.colorValueBoxShadow&&(e.shadowBlur=1.2*h,e.shadowColor=t.colorValueBoxShadow),t.colorValueBoxBackground&&(e.fillStyle=t.colorValueBoxBackground,e.fill()),e.closePath(),e.restore(),b(e,t,f,v),e.fillStyle=t.colorValueText,e.textAlign="center",e.textBaseline="alphabetic",e.fillText(s,A+k/2,o+T/2-p/3),e.restore()}}function x(e){var t=e.value,i=e.minValue,r=e.maxValue,o=.01*(r-i);return{normal:t<i?i:t>r?r:t,indented:t<i?i-o:t>r?r+o:t}}function k(e,t,i,r,o){i.beginPath(),i.arc(0,0,J(e),0,2*Q,!0),i.lineWidth=t,i.strokeStyle=o?K.linearGradient(i,r,o,e):r,i.stroke(),i.closePath()}function T(e,t){var i=X.pixelRatio;return e.maxRadius||(e.maxRadius=e.max-t.borderShadowWidth-t.borderOuterWidth*i-t.borderMiddleWidth*i-t.borderInnerWidth*i+(t.borderOuterWidth?.5:0)+(t.borderMiddleWidth?.5:0)+(t.borderInnerWidth?.5:0)),e.maxRadius}function S(e,t){var i=X.pixelRatio,r=t.borderShadowWidth*i,o=e.max-r-t.borderOuterWidth*i/2,n=o-t.borderOuterWidth*i/2-t.borderMiddleWidth*i/2+.5,a=n-t.borderMiddleWidth*i/2-t.borderInnerWidth*i/2+.5,l=T(e,t),s=void 0,d=!1;e.save(),t.borderOuterWidth&&(d=K.drawShadow(e,t,d),k(o,t.borderOuterWidth*i,e,t.colorBorderOuter,t.colorBorderOuterEnd)),t.borderMiddleWidth&&(d=K.drawShadow(e,t,d),k(n,t.borderMiddleWidth*i,e,t.colorBorderMiddle,t.colorBorderMiddleEnd)),t.borderInnerWidth&&(d=K.drawShadow(e,t,d),k(a,t.borderInnerWidth*i,e,t.colorBorderInner,t.colorBorderInnerEnd)),K.drawShadow(e,t,d),e.beginPath(),e.arc(0,0,J(l),0,2*Q,!0),t.colorPlateEnd?(s=e.createRadialGradient(0,0,l/2,0,0,l),s.addColorStop(0,t.colorPlate),s.addColorStop(1,t.colorPlateEnd)):s=t.colorPlate,e.fillStyle=s,e.fill(),e.closePath(),e.restore()}function O(e,t){var i=e.max*(parseFloat(t.highlightsWidth)||0)/100;if(i){var r=J(C(e,t)-i/2),o=0,n=t.highlights.length,a=(t.maxValue-t.minValue)/t.ticksAngle;for(e.save();o<n;o++){var l=t.highlights[o];e.beginPath(),e.rotate(ee),e.arc(0,0,r,K.radians(t.startAngle+(l.from-t.minValue)/a),K.radians(t.startAngle+(l.to-t.minValue)/a),!1),e.strokeStyle=l.color,e.lineWidth=i,e.stroke(),e.closePath(),e.restore(),e.save()}}}function A(e,t){var i=C(e,t),r=void 0,o=void 0,n=void 0,a=0,l=0,s=Math.abs(t.minorTicks)||0,d=t.ticksAngle/(t.maxValue-t.minValue);for(e.lineWidth=X.pixelRatio,e.strokeStyle=t.colorMinorTicks||t.colorStrokeTicks,e.save(),t.exactTicks?(o=t.maxValue-t.minValue,r=s?o/s:0,l=(Z.mod(t.majorTicks[0],s)||0)*d):r=s*(t.majorTicks.length-1);a<r;++a)(n=t.startAngle+l+a*(t.ticksAngle/r))<=t.ticksAngle+t.startAngle&&(e.rotate(K.radians(n)),e.beginPath(),e.moveTo(0,i),e.lineTo(0,i-.075*e.max),P(e))}function C(e,t){var i=e.max/100;return T(e,t)-5*i-(t.barWidth?2*(parseFloat(t.barStrokeWidth)||0)+((parseFloat(t.barWidth)||0)+5)*i:0)}function V(e,t){K.prepareTicks(t);var i=J(C(e,t)),r=void 0,o=void 0,n=t.majorTicks.length,a=X.pixelRatio;for(e.lineWidth=2*a,e.save(),o=t.colorMajorTicks instanceof Array?t.colorMajorTicks:new Array(n).fill(t.colorStrokeTicks||t.colorMajorTicks),r=0;r<n;++r)e.strokeStyle=o[r],e.rotate(K.radians(N(t,t.exactTicks?t.majorTicks[r]:r,n))),e.beginPath(),e.moveTo(0,i),e.lineTo(0,i-.15*e.max),P(e);t.strokeTicks&&(e.strokeStyle=t.colorStrokeTicks||o[0],e.rotate(ee),e.beginPath(),e.arc(0,0,i,K.radians(t.startAngle),K.radians(t.startAngle+t.ticksAngle),!1),P(e))}function N(e,t,i){if(e.exactTicks){var r=e.ticksAngle/(e.maxValue-e.minValue);return e.startAngle+r*(t-e.minValue)}return e.startAngle+t*(e.ticksAngle/(i-1))}function P(e){e.stroke(),e.restore(),e.closePath(),e.save()}function j(e,t){var i=C(e,t)-.15*e.max,r={},o=0,n=t.majorTicks.length,a="needle"!==t.animationTarget,l=t.colorNumbers instanceof Array?t.colorNumbers:new Array(n).fill(t.colorNumbers),s=a?-(t.value-t.minValue)/(t.maxValue-t.minValue)*t.ticksAngle:0;for(a&&(e.save(),e.rotate(-K.radians(s))),e.font=K.font(t,"Numbers",e.max/200),e.lineWidth=0,e.textAlign="center",e.textBaseline="middle";o<n;++o){var d=s+N(t,t.exactTicks?t.majorTicks[o]:o,n),u=e.measureText(t.majorTicks[o]).width,c=t.fontNumbersSize,h=Math.sqrt(u*u+c*c)/2,f=K.radialPoint(i-h-t.numbersMargin/100*e.max,K.radians(d));360===d&&(d=0),r[d]||(r[d]=!0,e.fillStyle=l[o],e.fillText(t.majorTicks[o],f.x,f.y))}a&&e.restore()}function M(e,t){t.title&&(e.save(),e.font=K.font(t,"Title",e.max/200),e.fillStyle=t.colorTitle,e.textAlign="center",e.fillText(t.title,0,-e.max/4.25,.8*e.max),e.restore())}function B(e,t){t.units&&(e.save(),e.font=K.font(t,"Units",e.max/200),e.fillStyle=t.colorUnits,e.textAlign="center",e.fillText(t.units,0,e.max/3.25,.8*e.max),e.restore())}function W(e,t){if(t.needle){var i=t.ticksAngle<360?K.normalizedValue(t).indented:t.value,r=T(e,t),o=J(r/100*t.needleCircleSize),n=J(r/100*t.needleCircleSize*.75),a=J(r/100*t.needleEnd),l=J(t.needleStart?r/100*t.needleStart:0),s=r/100*t.needleWidth,d=r/100*t.needleWidth/2,u=X.pixelRatio,c="needle"!==t.animationTarget;e.save(),K.drawNeedleShadow(e,t),e.rotate(K.radians(c?t.startAngle:t.startAngle+(i-t.minValue)/(t.maxValue-t.minValue)*t.ticksAngle)),e.fillStyle=K.linearGradient(e,t.colorNeedle,t.colorNeedleEnd,a-l),"arrow"===t.needleType?(e.beginPath(),e.moveTo(-d,-l),e.lineTo(-s,0),e.lineTo(-1*u,a),e.lineTo(u,a),e.lineTo(s,0),e.lineTo(d,-l),e.closePath(),e.fill(),e.beginPath(),e.lineTo(-.5*u,a),e.lineTo(-1*u,a),e.lineTo(-s,0),e.lineTo(-d,-l),e.lineTo(d/2*u-2*u,-l),e.closePath(),e.fillStyle=t.colorNeedleShadowUp,e.fill()):(e.beginPath(),e.moveTo(-d,a),e.lineTo(-d,l),e.lineTo(d,l),e.lineTo(d,a),e.closePath(),e.fill()),t.needleCircleSize&&(e.restore(),K.drawNeedleShadow(e,t),t.needleCircleOuter&&(e.beginPath(),e.arc(0,0,o,0,2*Q,!0),e.fillStyle=K.linearGradient(e,t.colorNeedleCircleOuter,t.colorNeedleCircleOuterEnd,o),e.fill(),e.closePath()),t.needleCircleInner&&(e.beginPath(),e.arc(0,0,n,0,2*Q,!0),e.fillStyle=K.linearGradient(e,t.colorNeedleCircleInner,t.colorNeedleCircleInnerEnd,n),e.fill(),e.closePath()),e.restore())}}function _(e,t,i){K.drawValueBox(e,t,i,0,e.max-.33*e.max,e.max)}function E(e,t){var i=e.max/100,r=T(e,t)-5*i,o=parseFloat(t.barStrokeWidth)||0,n=(parseFloat(t.barWidth)||0)*i,a=r-2*o-n,l=(r-a)/2,s=a+l,d=o/s,u=t.startAngle,c=t.startAngle+t.ticksAngle;e.save(),e.rotate(ee),o&&(e.beginPath(),e.arc(0,0,s,K.radians(u)-d,K.radians(c)+d,!1),e.strokeStyle=t.colorBarStroke,e.lineWidth=2*l,e.stroke(),e.closePath()),n&&(e.beginPath(),e.arc(0,0,s,K.radians(u),K.radians(c),!1),e.strokeStyle=t.colorBar,e.lineWidth=n,e.stroke(),e.closePath(),t.barShadow&&(e.beginPath(),e.arc(0,0,r,K.radians(u),K.radians(c),!1),e.clip(),e.beginPath(),e.strokeStyle=t.colorBar,e.lineWidth=1,e.shadowBlur=t.barShadow,e.shadowColor=t.colorBarShadow,e.shadowOffsetX=0,e.shadowOffsetY=0,e.arc(0,0,r,K.radians(t.startAngle),K.radians(t.startAngle+t.ticksAngle),!1),e.stroke(),e.closePath(),e.restore(),e.rotate(ee)),t.barProgress&&(e.beginPath(),e.arc(0,0,s,K.radians(u),K.radians(u+(K.normalizedValue(t).normal-t.minValue)/(t.maxValue-t.minValue)*t.ticksAngle),!1),e.strokeStyle=t.colorBarProgress,e.lineWidth=n,e.stroke(),e.closePath())),e.restore()}function R(e){return e.options.animatedValue?e.options.value:e.value}var I=function e(t,i,r){null===t&&(t=Function.prototype);var o=Object.getOwnPropertyDescriptor(t,i);if(void 0===o){var n=Object.getPrototypeOf(t);return null===n?void 0:e(n,i,r)}if("value"in o)return o.value;var a=o.get;if(void 0!==a)return a.call(r)},D=function e(t,i,r,o){var n=Object.getOwnPropertyDescriptor(t,i);if(void 0===n){var a=Object.getPrototypeOf(t);null!==a&&e(a,i,r,o)}else if("value"in n&&n.writable)n.value=r;else{var l=n.set;void 0!==l&&l.call(o,r)}return r},z=function(){function e(e,t){for(var i=0;i<t.length;i++){var r=t[i];r.enumerable=r.enumerable||!1,r.configurable=!0,"value"in r&&(r.writable=!0),Object.defineProperty(e,r.key,r)}}return function(t,i,r){return i&&e(t.prototype,i),r&&e(t,r),t}}();Object.assign||Object.defineProperty(Object,"assign",{enumerable:!1,configurable:!0,writable:!0,value:function(e,t){if(void 0===e||null===e)throw new TypeError("Cannot convert first argument to object");for(var i=Object(e),r=1;r<arguments.length;r++){var o=arguments[r];if(void 0!==o&&null!==o)for(var n=Object.keys(Object(o)),a=0,l=n.length;a<l;a++){var s=n[a],d=Object.getOwnPropertyDescriptor(o,s);void 0!==d&&d.enumerable&&(i[s]=o[s])}}return i}}),Array.prototype.indexOf||Object.defineProperty(Array.prototype,"indexOf",{value:function(e,t){var i;if(null===this)throw new TypeError('"this" is null or not defined');var r=Object(this),o=r.length>>>0;if(0===o)return-1;var n=+t||0;if(Math.abs(n)===1/0&&(n=0),n>=o)return-1;for(i=Math.max(n>=0?n:o-Math.abs(n),0);i<o;){if(i in r&&r[i]===e)return i;i++}return-1}}),Array.prototype.fill||Object.defineProperty(Array.prototype,"fill",{value:function(e){if(null===this)throw new TypeError("this is null or not defined");for(var t=Object(this),i=t.length>>>0,r=arguments[1],o=r>>0,n=o<0?Math.max(i+o,0):Math.min(o,i),a=arguments[2],l=void 0===a?i:a>>0,s=l<0?Math.max(i+l,0):Math.min(l,i);n<s;)t[n]=e,n++;return t}}),"undefined"==typeof window&&(window="undefined"==typeof global?{}:global);var F=function(){function e(){r(this,e),this._events={},this.addListener=this.on,this.removeListener=this.off}return z(e,[{key:"emit",value:function(e){if(this._events[e]){for(var t=0,i=this._events[e].length,r=arguments.length,o=Array(r>1?r-1:0),n=1;n<r;n++)o[n-1]=arguments[n];for(;t<i;t++)this._events[e][t]&&this._events[e][t].apply(this,o)}}},{key:"once",value:function(e){for(var t=arguments.length,i=Array(t>1?t-1:0),r=1;r<t;r++)i[r-1]=arguments[r];for(var o=0,n=i.length,a=this;o<n;o++)!function(){var t=i[o],r=function i(){a.off(e,i),t.apply(a,arguments)};i[o]=r}();this.on.apply(this,[e].concat(i))}},{key:"on",value:function(e){this._events[e]||(this._events[e]=[]);for(var t=0,i=arguments.length<=1?0:arguments.length-1;t<i;t++)this._events[e].push(arguments.length<=t+1?void 0:arguments[t+1])}},{key:"off",value:function(e){if(this._events[e])for(var t=0,i=arguments.length<=1?0:arguments.length-1;t<i;t++)for(var r=arguments.length<=t+1?void 0:arguments[t+1],o=void 0;~(o=this._events[e].indexOf(r));)this._events[e].splice(o,1)}},{key:"removeAllListeners",value:function(e){delete this._events[e]}},{key:"listeners",get:function(){return this._events}}]),e}(),G=o("requestAnimationFrame")||function(e){return setTimeout(function(){return e((new Date).getTime())},1e3/60)},L={linear:function(e){return e},quad:function(e){return Math.pow(e,2)},dequad:function(e){return 1-L.quad(1-e)},quint:function(e){return Math.pow(e,5)},dequint:function(e){return 1-Math.pow(1-e,5)},cycle:function(e){return 1-Math.sin(Math.acos(e))},decycle:function(e){return Math.sin(Math.acos(1-e))},bounce:function(e){return 1-L.debounce(1-e)},debounce:function(e){for(var t=0,i=1;1;t+=i,i/=2)if(e>=(7-4*t)/11)return-Math.pow((11-6*t-11*e)/4,2)+Math.pow(i,2)},elastic:function(e){return 1-L.delastic(1-e)},delastic:function(e){return Math.pow(2,10*(e-1))*Math.cos(20*Math.PI*1.5/3*e)}},U=function(){function e(){var t=arguments.length>0&&void 0!==arguments[0]?arguments[0]:"linear",i=arguments.length>1&&void 0!==arguments[1]?arguments[1]:250,o=arguments.length>2&&void 0!==arguments[2]?arguments[2]:function(){},n=arguments.length>3&&void 0!==arguments[3]?arguments[3]:function(){};if(r(this,e),this.duration=i,this.rule=t,this.draw=o,this.end=n,"function"!=typeof this.draw)throw new TypeError("Invalid animation draw callback:",o);if("function"!=typeof this.end)throw new TypeError("Invalid animation end callback:",n)}return z(e,[{key:"animate",value:function(e,t){var i=this;this.frame&&this.cancel();var r=window.performance&&window.performance.now?window.performance.now():o("animationStartTime")||Date.now();e=e||this.draw,t=t||this.end,this.draw=e,this.end=t,this.frame=G(function(o){return n(o,e,r,L[i.rule]||i.rule,i.duration,t,i)})}},{key:"cancel",value:function(){if(this.frame){(o("cancelAnimationFrame")||function(e){})(this.frame),this.frame=null}}},{key:"destroy",value:function(){this.cancel(),this.draw=null,this.end=null}}]),e}();U.rules=L;var q=function(){function t(i,o,n){r(this,t),this.options=i,this.element=o.toLowerCase(),this.type=t.toDashed(n),this.Type=e[n],this.mutationsObserved=!1,this.isObservable=!!window.MutationObserver,window.GAUGES_NO_AUTO_INIT||t.domReady(this.traverse.bind(this))}return z(t,[{key:"isValidNode",value:function(e){return!(!e.tagName||e.tagName.toLowerCase()!==this.element||e.getAttribute("data-type")!==this.type)}},{key:"traverse",value:function(){for(var e=document.getElementsByTagName(this.element),t=0,i=e.length;t<i;t++)this.process(e[t]);this.isObservable&&!this.mutationsObserved&&(new MutationObserver(this.observe.bind(this)).observe(document.body,{childList:!0,subtree:!0,attributes:!0,characterData:!0,attributeOldValue:!0,characterDataOldValue:!0}),this.mutationsObserved=!0)}},{key:"observe",value:function(e){for(var t=0,i=e.length;t<i;t++){var r=e[t];if("attributes"===r.type&&"data-type"===r.attributeName&&this.isValidNode(r.target)&&r.oldValue!==this.type)setTimeout(this.process.bind(this,r.target));else if(r.addedNodes&&r.addedNodes.length)for(var o=0,n=r.addedNodes.length;o<n;o++)setTimeout(this.process.bind(this,r.addedNodes[o]))}}},{key:"process",value:function(e){var i=this;if(!this.isValidNode(e))return null;var r=void 0,o=JSON.parse(JSON.stringify(this.options)),n=null;for(r in o)if(o.hasOwnProperty(r)){var a=t.toAttributeName(r),l=t.parse(e.getAttribute(a));null!==l&&void 0!==l&&(o[r]=l)}return o.renderTo=e,n=new this.Type(o),n.draw&&n.draw(),this.isObservable?(n.observer=new MutationObserver(function(r){r.forEach(function(r){if("attributes"===r.type){var o=r.attributeName.toLowerCase(),a=e.getAttribute(o).toLowerCase();if("data-type"===o&&a&&a!==i.type)n.observer.disconnect(),delete n.observer,n.destroy&&n.destroy();else if("data-"===o.substr(0,5)){var l=o.substr(5).split("-").map(function(e,t){return t?e.charAt(0).toUpperCase()+e.substr(1):e}).join(""),s={};s[l]=t.parse(e.getAttribute(r.attributeName)),"value"===l?n&&(n.value=s[l]):n.update&&n.update(s)}}})}),n.observer.observe(e,{attributes:!0}),n):n}}],[{key:"parse",value:function(e){if("true"===e)return!0;if("false"===e)return!1;if("undefined"!==e){if("null"===e)return null;if(/^[-+#.\w\d\s]+(?:,[-+#.\w\d\s]*)+$/.test(e))return e.split(",");try{return JSON.parse(e)}catch(e){}return e}}},{key:"toDashed",value:function(e){for(var t=e.split(/(?=[A-Z])/),i=1,r=t.length,o=t[0].toLowerCase();i<r;i++)o+="-"+t[i].toLowerCase();return o}},{key:"toCamelCase",value:function(e){for(var t=!(arguments.length>1&&void 0!==arguments[1])||arguments[1],i=e.split(/-/),r=0,o=i.length,n="";r<o;r++)n+=r||t?i[r][0].toUpperCase()+i[r].substr(1).toLowerCase():i[r].toLowerCase();return n}},{key:"toAttributeName",value:function(e){return"data-"+t.toDashed(e)}},{key:"domReady",value:function(e){if(/comp|inter|loaded/.test((window.document||{}).readyState+""))return e();window.addEventListener?window.addEventListener("DOMContentLoaded",e,!1):window.attachEvent&&window.attachEvent("onload",e)}}]),t}(),X=function(){function e(t,i,o){r(this,e),e.collection.push(this),this.width=i||0,this.height=o||0,this.element=t,this.init()}return z(e,[{key:"init",value:function(){var t=e.pixelRatio;this.element.width=this.width*t,this.element.height=this.height*t,this.element.style.width=this.width+"px",this.element.style.height=this.height+"px",this.elementClone=this.element.cloneNode(!0),this.context=this.element.getContext("2d"),this.contextClone=this.elementClone.getContext("2d"),this.drawWidth=this.element.width,this.drawHeight=this.element.height,this.drawX=this.drawWidth/2,this.drawY=this.drawHeight/2,this.minSide=this.drawX<this.drawY?this.drawX:this.drawY,this.elementClone.initialized=!1,this.contextClone.translate(this.drawX,this.drawY),this.contextClone.save(),this.context.translate(this.drawX,this.drawY),this.context.save(),this.context.max=this.contextClone.max=this.minSide,this.context.maxRadius=this.contextClone.maxRadius=null}},{key:"destroy",value:function(){var t=e.collection.indexOf(this);~t&&e.collection.splice(t,1),this.context.clearRect(-this.drawX,-this.drawY,this.drawWidth,this.drawHeight),this.context.max=null,delete this.context.max,this.context.maxRadius=null,delete this.context.maxRadius,this.context=null,this.contextClone=null,this.elementClone=null,this.element=null,this.onRedraw=null}},{key:"commit",value:function(){var t=e.pixelRatio;return 1!==t&&(this.contextClone.scale(t,t),this.contextClone.save()),this}},{key:"redraw",value:function(){return this.init(),this.onRedraw&&this.onRedraw(),this}}],[{key:"redraw",value:function(){for(var t=0,i=e.collection.length;t<i;t++)e.collection[t].redraw()}},{key:"pixelRatio",get:function(){return window.devicePixelRatio||1}}]),e}();X.collection=[],window.matchMedia&&window.matchMedia("screen and (min-resolution: 2dppx)").addListener(X.redraw);var Y={renderTo:null,width:0,height:0,minValue:0,maxValue:100,value:0,units:!1,exactTicks:!1,majorTicks:[0,20,40,60,80,100],minorTicks:10,strokeTicks:!0,animatedValue:!1,animateOnInit:!1,title:!1,borders:!0,numbersMargin:1,listeners:null,valueInt:3,valueDec:2,majorTicksInt:1,majorTicksDec:0,animation:!0,animationDuration:500,animationRule:"cycle",colorPlate:"#fff",colorPlateEnd:"",colorMajorTicks:"#444",colorMinorTicks:"#666",colorStrokeTicks:"",colorTitle:"#888",colorUnits:"#888",colorNumbers:"#444",colorNeedle:"rgba(240,128,128,1)",colorNeedleEnd:"rgba(255,160,122,.9)",colorValueText:"#444",colorValueTextShadow:"rgba(0,0,0,0.3)",colorBorderShadow:"rgba(0,0,0,0.5)",colorBorderOuter:"#ddd",colorBorderOuterEnd:"#aaa",colorBorderMiddle:"#eee",colorBorderMiddleEnd:"#f0f0f0",colorBorderInner:"#fafafa",colorBorderInnerEnd:"#ccc",colorValueBoxRect:"#888",colorValueBoxRectEnd:"#666",colorValueBoxBackground:"#babab2",colorValueBoxShadow:"rgba(0,0,0,1)",colorNeedleShadowUp:"rgba(2,255,255,0.2)",colorNeedleShadowDown:"rgba(188,143,143,0.45)",colorBarStroke:"#222",colorBar:"#ccc",colorBarProgress:"#888",colorBarShadow:"#000",fontNumbers:"Arial",fontTitle:"Arial",fontUnits:"Arial",fontValue:"Arial",fontNumbersSize:20,fontTitleSize:24,fontUnitsSize:22,fontValueSize:26,fontNumbersStyle:"normal",fontTitleStyle:"normal",fontUnitsStyle:"normal",fontValueStyle:"normal",fontNumbersWeight:"normal",fontTitleWeight:"normal",fontUnitsWeight:"normal",fontValueWeight:"normal",needle:!0,needleShadow:!0,needleType:"arrow",needleStart:5,needleEnd:85,needleWidth:4,borderOuterWidth:3,borderMiddleWidth:3,borderInnerWidth:3,borderShadowWidth:3,valueBox:!0,valueBoxStroke:5,valueBoxWidth:0,valueText:"",valueTextShadow:!0,valueBoxBorderRadius:2.5,highlights:[{from:20,to:60,color:"#eee"},{from:60,to:80,color:"#ccc"},{from:80,to:100,color:"#999"}],highlightsWidth:15,barWidth:20,barStrokeWidth:0,barProgress:!0,barShadow:0};a.prototype=Object.create(Array.prototype),a.prototype.constructor=a,a.prototype.get=function(e){if("string"==typeof e)for(var t=0,i=this.length;t<i;t++){var r=this[t].options.renderTo.tagName?this[t].options.renderTo:document.getElementById(this[t].options.renderTo||"");if(r.getAttribute("id")===e)return this[t]}else if("number"==typeof e)return this[e];return null};var H="2.1.5",J=(Math.round,Math.abs),$=new a;$.version=H;var Z=function(o){function n(i){r(this,n);var o=t(this,(n.__proto__||Object.getPrototypeOf(n)).call(this)),a=o.constructor.name;if("BaseGauge"===a)throw new TypeError("Attempt to instantiate abstract class!");if($.push(o),i.listeners&&Object.keys(i.listeners).forEach(function(e){(i.listeners[e]instanceof Array?i.listeners[e]:[i.listeners[e]]).forEach(function(t){o.on(e,t)})}),o.version=H,o.type=e[a]||n,o.initialized=!1,i.minValue=parseFloat(i.minValue),i.maxValue=parseFloat(i.maxValue),i.value=parseFloat(i.value)||0,i.borders||(i.borderInnerWidth=i.borderMiddleWidth=i.borderOuterWidth=0),!i.renderTo)throw TypeError("Canvas element was not specified when creating the Gauge object!");var l=i.renderTo.tagName?i.renderTo:document.getElementById(i.renderTo);if(!(l instanceof HTMLCanvasElement))throw TypeError("Given gauge canvas element is invalid!");return i.width=parseFloat(i.width)||0,i.height=parseFloat(i.height)||0,i.width&&i.height||(i.width||(i.width=l.parentNode?l.parentNode.offsetWidth:l.offsetWidth),i.height||(i.height=l.parentNode?l.parentNode.offsetHeight:l.offsetHeight)),o.options=i||{},o.options.animateOnInit&&(o._value=o.options.value,o.options.value=o.options.minValue),o.canvas=new X(l,i.width,i.height),o.canvas.onRedraw=o.draw.bind(o),o.animation=new U(i.animationRule,i.animationDuration),o}return i(n,o),z(n,[{key:"update",value:function(e){return Object.assign(this.options,this.type.configure(e||{})),this.canvas.width=this.options.width,this.canvas.height=this.options.height,this.animation.rule=this.options.animationRule,this.animation.duration=this.options.animationDuration,this.canvas.redraw(),this}},{key:"destroy",value:function(){var e=$.indexOf(this);~e&&$.splice(e,1),this.canvas.destroy(),this.canvas=null,this.animation.destroy(),this.animation=null,this.emit("destroy")}},{key:"draw",value:function(){return this.options.animateOnInit&&!this.initialized&&(this.value=this._value,this.initialized=!0,this.emit("init")),this.emit("render"),this}},{key:"value",set:function(e){var t=this;e=n.ensureValue(e,this.options.minValue);var i=this.options.value;if(e!==i)if(this.options.animation){if(this.animation.frame&&(this.options.value=this._value,this._value===e))return this.animation.cancel(),void delete this._value;void 0===this._value&&(this._value=e),this.emit("animationStart"),this.animation.animate(function(r){var o=i+(e-i)*r;t.options.animatedValue&&t.emit("value",o,t.value),t.options.value=o,t.draw(),t.emit("animate",r,t.options.value)},function(){void 0!==t._value&&(t.emit("value",t._value,t.value),t.options.value=t._value,delete t._value),t.draw(),t.emit("animationEnd")})}else this.emit("value",e,this.value),this.options.value=e,this.draw()},get:function(){return void 0===this._value?this.options.value:this._value}}],[{key:"configure",value:function(e){return e}},{key:"initialize",value:function(e,t){return new q(t,"canvas",e)}},{key:"fromElement",value:function(e){var t=q.toCamelCase(e.getAttribute("data-type")),i=e.attributes,r=0,o=i.length,n={};if(t){for(/Gauge$/.test(t)||(t+="Gauge");r<o;r++)n[q.toCamelCase(i[r].name.replace(/^data-/,""),!1)]=q.parse(i[r].value);new q(n,e.tagName,t).process(e)}}},{key:"ensureValue",value:function(e){var t=arguments.length>1&&void 0!==arguments[1]?arguments[1]:0;return e=parseFloat(e),!isNaN(e)&&isFinite(e)||(e=parseFloat(t)||0),e}},{key:"mod",value:function(e,t){return(e%t+t)%t}},{key:"version",get:function(){return H}}]),n}(F);void 0!==e&&(e.BaseGauge=Z,e.gauges=(window.document||{}).gauges=$);var K={roundRect:d,padValue:u,formatMajorTickNumber:c,radians:h,radialPoint:f,linearGradient:v,drawNeedleShadow:p,drawValueBox:y,verifyError:l,prepareTicks:s,drawShadow:m,font:g,normalizedValue:x},Q=Math.PI,ee=Q/2,te=Object.assign({},Y,{ticksAngle:270,startAngle:45,colorNeedleCircleOuter:"#f0f0f0",colorNeedleCircleOuterEnd:"#ccc",colorNeedleCircleInner:"#e8e8e8",colorNeedleCircleInnerEnd:"#f5f5f5",needleCircleSize:10,needleCircleInner:!0,needleCircleOuter:!0,needleStart:20,animationTarget:"needle",useMinPath:!1,barWidth:0}),ie=function(e){function o(e){return r(this,o),e=Object.assign({},te,e||{}),t(this,(o.__proto__||Object.getPrototypeOf(o)).call(this,o.configure(e)))}return i(o,e),z(o,[{key:"draw",value:function(){try{var e=this.canvas,t=[-e.drawX,-e.drawY,e.drawWidth,e.drawHeight],i=t[0],r=t[1],n=t[2],a=t[3],l=this.options;if("needle"===l.animationTarget){if(!e.elementClone.initialized){var s=e.contextClone;s.clearRect(i,r,n,a),s.save(),this.emit("beforePlate"),S(s,l),this.emit("beforeHighlights"),O(s,l),this.emit("beforeMinorTicks"),A(s,l),this.emit("beforeMajorTicks"),V(s,l),this.emit("beforeNumbers"),j(s,l),this.emit("beforeTitle"),M(s,l),this.emit("beforeUnits"),B(s,l),e.elementClone.initialized=!0}this.canvas.commit(),e.context.clearRect(i,r,n,a),e.context.save(),e.context.drawImage(e.elementClone,i,r,n,a),e.context.save(),this.emit("beforeProgressBar"),E(e.context,l),this.emit("beforeValueBox"),_(e.context,l,R(this)),this.emit("beforeNeedle"),W(e.context,l)}else{var d=-K.radians((l.value-l.minValue)/(l.maxValue-l.minValue)*l.ticksAngle);if(e.context.clearRect(i,r,n,a),e.context.save(),this.emit("beforePlate"),S(e.context,l),e.context.rotate(d),this.emit("beforeHighlights"),O(e.context,l),this.emit("beforeMinorTicks"),A(e.context,l),this.emit("beforeMajorTicks"),V(e.context,l),this.emit("beforeNumbers"),j(e.context,l),this.emit("beforeProgressBar"),E(e.context,l),e.context.rotate(-d),e.context.save(),!e.elementClone.initialized){var u=e.contextClone;u.clearRect(i,r,n,a),u.save(),this.emit("beforeTitle"),M(u,l),this.emit("beforeUnits"),B(u,l),this.emit("beforeNeedle"),W(u,l),e.elementClone.initialized=!0}e.context.drawImage(e.elementClone,i,r,n,a)}this.emit("beforeValueBox"),_(e.context,l,R(this)),I(o.prototype.__proto__||Object.getPrototypeOf(o.prototype),"draw",this).call(this)}catch(e){K.verifyError(e)}return this}},{key:"value",set:function(e){e=Z.ensureValue(e,this.options.minValue),this.options.animation&&360===this.options.ticksAngle&&this.options.useMinPath&&(this._value=e,e=this.options.value+((e-this.options.value)%360+540)%360-180),D(o.prototype.__proto__||Object.getPrototypeOf(o.prototype),"value",e,this)},get:function(){return I(o.prototype.__proto__||Object.getPrototypeOf(o.prototype),"value",this)}}],[{key:"configure",value:function(e){return e.barWidth>50&&(e.barWidth=50),isNaN(e.startAngle)&&(e.startAngle=45),isNaN(e.ticksAngle)&&(e.ticksAngle=270),e.ticksAngle>360&&(e.ticksAngle=360),e.ticksAngle<0&&(e.ticksAngle=0),e.startAngle<0&&(e.startAngle=0),e.startAngle>360&&(e.startAngle=360),e}}]),o}(Z);void 0!==e&&(e.RadialGauge=ie),Z.initialize("RadialGauge",te),"undefined"!=typeof module&&Object.assign(e,{Collection:a,GenericOptions:Y,Animation:U,BaseGauge:Z,drawings:K,SmartCanvas:X,DomObserver:q,vendorize:o})}("undefined"!=typeof module?module.exports:window);
