By zaferturan
#86721 i use AT+CWMODE_DEF=1 command in order to fix station mode but when i turn off the power everytime AT+CWMODE_DEF becomes 2. i mean this command does not write in to flash. any help for permament flashing . because my network uses 192.168.0.xxx but esp8266 gets different ip adreesses. i can show it on routers "connected devices" table as seen on screenshot.
