How to pass the(serverClients[i].read() to byte array on esp
Posted: Sun May 17, 2020 9:28 pm
In a sketch of arduino thre is example Wifi Telnet To Serial with esp8266 there is a piece of code that is used to receive data from a client:
This data is sent to the console or the serial port, but I need to capture that data and store it in a byte array:
Someone can tell me how to do it?
//check clients for data
for(i = 0; i < MAX_SRV_CLIENTS; i++){
if (serverClients[i] && serverClients[i].connected()){
if(serverClients[i].available()){
//get data from the telnet client and push it to the UART
while(serverClients[i].available())
Serial.write(serverClients[i].read());
byte bufferMSGfromCliente[1024]
