By Trampas
#87319 I am trying to use the HSPI on the ESP8266 as master. However I it appears that the MISO pin is being driven high by the ESP8266 such that my slave device when driven low can only pull the pin down to ~1.25V, right on the edge of logic high/low thus causing lots of bus errors.
Has anyone else seen this before?
