By nigelbe
#16702 Thanks for that but I saw it after I'd got it working with the help of similar code for the US.
Code: Select allint dst (time_t t) // calculate if summertime
   tmElements_t te;
   te.Year = year(t)-1970;
   te.Month =3;
   te.Day =1;
   te.Hour = 0;
   te.Minute = 0;
   te.Second = 0;
   time_t dstStart,dstEnd, current;
   dstStart = makeTime(te);
   dstStart = lastSunday(dstStart);
   dstStart += 2*SECS_PER_HOUR;  //2AM
   te.Month=10;
   dstEnd = makeTime(te);
   dstEnd = lastSunday(dstEnd);
   dstEnd += SECS_PER_HOUR;  //1AM
   if (t>=dstStart && t<dstEnd) return (3600);  //Add back in one hours worth of seconds - DST in effect
   else return (0);  //NonDST
time_t lastSunday(time_t t)
   t = nextSunday(t);  //Once, first Sunday
   if(day(t) < 4) return t += 4 * SECS_PER_WEEK;
   else return t += 3 * SECS_PER_WEEK;
Now my 4 digit clock works fine.
By nigelbe
#16704 The whole 4 digit clock is here:
Code: Select all/*
* espNTPdigitalClock.ino
* Created: 5/6/2015 2:17:03 PM
* Author: Nigel
#include <WiFiUdp.h>
#include <Time.h>
#include <Wire.h>
#include <Adafruit_LEDBackpack.h>
#include <Adafruit_GFX.h>
char ssid[] = "***";  //  your network SSID (name)
char pass[] = "***";       // your network password
#define UPDATESECS 900UL   // update every 15 minutes
time_t update;
bool flag = true;
Adafruit_7segment disp = Adafruit_7segment();
unsigned int localPort = 2390;      // local port to listen for UDP packets
IPAddress timeServer(129, 6, 15, 28); // time.nist.gov NTP server
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP
WiFiUDP udp;
unsigned long secsSince1900;
void setup()
   Wire.pins(0,2);
   Wire.begin();
   delay(10);
   disp.begin(0x70);
   notime();
   Serial.println(ssid);
   WiFi.begin(ssid, pass);
      Serial.print(".");
   Serial.println("");
   Serial.println("Starting UDP");
   udp.begin(localPort);
   Serial.print("Local port: ");
   Serial.println(udp.localPort());
   setNTPtime();
void loop()
   if(now() > update) setNTPtime();
   int h = hourFormat12(now());
   int m = minute(now());
   disp.print(h * 100 + m);
   disp.drawColon(true);
   disp.writeDisplay();
   if(flag && (now() % 10UL == 0UL)) printTime("Now ",now());
   else flag = true;
void setNTPtime()
   time_t epoch = 0UL;
   while((epoch =  getFromNTP()) == 0) delay(5000);
   epoch -= 2208988800UL;
   setTime(epoch += dst(epoch));
   update = now() + UPDATESECS;
unsigned long getFromNTP()
   sendNTPpacket(timeServer); // send an NTP packet to a time server
   // wait to see if a reply is available
   delay(1000);
   int cb = udp.parsePacket();
   if (!cb) {
      Serial.println("no packet yet");
      return 0UL;
   Serial.print("packet received, length=");
   Serial.println(cb);
   // We've received a packet, read the data from it
   udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
   //the timestamp starts at byte 40 of the received packet and is four bytes,
   // or two words, long. First, extract the two words:
   unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
   unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
   // combine the four bytes (two words) into a long integer
   // this is NTP time (seconds since Jan 1 1900):
   return (unsigned long) highWord << 16 | lowWord;
// send an NTP request to the time server at the given address
unsigned long sendNTPpacket(IPAddress& address)
   Serial.println("sending NTP packet...");
   // set all bytes in the buffer to 0
   memset(packetBuffer, 0, NTP_PACKET_SIZE);
   // Initialize values needed to form NTP request
   // (see URL above for details on the packets)
   packetBuffer[0] = 0b11100011;   // LI, Version, Mode
   packetBuffer[1] = 0;     // Stratum, or type of clock
   packetBuffer[2] = 6;     // Polling Interval
   packetBuffer[3] = 0xEC;  // Peer Clock Precision
   // 8 bytes of zero for Root Delay & Root Dispersion
   packetBuffer[12]  = 49;
   packetBuffer[13]  = 0x4E;
   packetBuffer[14]  = 49;
   packetBuffer[15]  = 52;
   // all NTP fields have been given values, now
   // you can send a packet requesting a timestamp:
   udp.beginPacket(address, 123); //NTP requests are to port 123
   udp.write(packetBuffer, NTP_PACKET_SIZE);
   udp.endPacket();
   tmElements_t te;
   te.Month =3;
   te.Day =1;
   te.Hour = 0;
   te.Minute = 0;
   te.Second = 0;
   te.Month=10;
void printTime(const char s[],time_t t)
   flag =false;
   Serial.print(s);
   printLeading0(hour(t));
   Serial.print(":");
   printLeading0(minute(t));
   Serial.print(":");
   printLeading0(second(t));
   Serial.print(" ");
   Serial.print(dayStr(weekday(t)));
   Serial.print(" ");
   Serial.print(day(t));
   Serial.print(" ");
   Serial.print(monthStr(month(t)));
   Serial.print(" ");
   Serial.println(year(t));
void printLeading0(int n)
   if(n < 10) Serial.print("0");
   Serial.print(n);
void notime(void)
   disp.drawColon(false);
   disp.print(8888);
Thanks again for all the help I've had with the project.
Nigel.
