Re: Integrate EmonLib (energy monitor) library to ESP
Posted: Wed May 20, 2015 11:48 am
Hi, ok, i can see how that would be worth doing depending on the setup. i also have a setup running in the past but just using the full range of the 100A, maybe after we get this running i will experiment with lowering the range.
I have been working also using the same site (openenergymonitor.org), and i made my calcualtions based on another pagehttp://openenergymonitor.org/emon/buildingblocks/ct-sensors-interface
This is a more simple project to just get the current calculations from the CT sensor.
I believe my calculations for the voltage divider should be correct.
Let me know when you start working on the library, i will be interested to help where i can.
