By danbicks
#18245 igrr,
Thanks for such a professional polite response. I think if this disrespect verbally from other members did not occur this would have blown over and I am sure not been an issue. That is the point we need to take from this.
We are all developers here in one way or another, for example my area of expertise is electronics, but I do like to create and innovate projects which require software. Some of us may not be specialists in this area but should be encouraged to pursue this and not be negatively compromised.
Keep up the outstanding work with the IDE, but please ensure members participating in this process act in a professional manner.
Dans
By ozayturay
#18250 +1 for igrr's professional response.
Thank you for this great project. Although I like the Arduino IDE approach, I decided to use Sming Framework for my ongoing projects, but Arduino ESP8266 should continue it's evolution, because it is also a good project and deserve being better.
By ficeto
#18284 the users are the only ones that will suffer... I could not care less for folks like you... one day you will get it... maybe... they were the reason this all was done, and they are the ones that will not get it, and the ones that did, will have to switch... to what? To exactly the same thing... because there is only one way to use it... it's in the API... (not ana... whatever's way). You can all rest assured that no more of my anything will get to you, everyone can have and get what they want, so free choice... mine is to not share anything with you. If I had the power I would revert all of my commits, not that they are something special, just you do not deserve to have anything else but what you have had. I know well what you are... I used to run much larger community that what you are... I know sheep like you... there is no reason in your broken minds... I put the proof in your face and you call the black, white... what's there else to communicate with you? I much rather spend my time coding things I care about than deal with you. The two days I spent "fighting" with the windmills are what's considered worth for 7 days of work on SPIFFS. That time is over, now time to have fun. Too sad this community has no delete button for the account... admins should take care of that!
