By tytower
#20472
BE sure to change the CS pin because the ESP8266 standard CS pin is IO15 which always has to be connected to ground!(in this case change it to 2)
I was wondering about this . Did you make a mistake?GPIO15 pin is not a chip select pin as far as I know . It is the MTDO pin used to boot the chip into a SDIO mode which no-one seems to know much about yet . Its a slave mode for SPI I think though
I think you can use any pin that will go high to act as CS (Chip Select) pin
By sigrokBlack
#20485 Hi,
when you look on the pin table from the Repository:
(From:https://raw.githubusercontent.com/Links2004/Arduino/esp8266/docs/pin_functions.png)
You can see that Function 2 of IO15 is HSPICS.
To boot the esp normaly, you need to connect IO15 to Ground. Nearly every espboard has it's io 15 connected to ground. Excluding my esp8266 201, where I had to solder wires on.
