By jh1995
#20887 At the beginning of May I compiled a sketch with OneWire.h library and let it run until 17th of June. The skecth worked 100% and Arduino IDE 1.6.1 reported a size of 36%.
Then I compiled the same code over with 1.6.4 and the reported size is now 46%. And it doesn't even work! But that could be an issue with OneWire.h that I'll post separately.
Fortunately the Downloads folder of my browser still had the 1.6.1 zip and I could restore my sensor.
Has anybody else noticed the compiled code size difference of 1.6.1 (at May 5th, 2015) vs 1.6.4 (at May 17th, 2015) ? My fault, I haven't checked the actual bytes value, only the reported percentage.
By jh1995
#21141 Finally I got few minutes to check it out.
Versions: 1.6.1 from 1st of May 2015 or so; 1.6.4-673-g8cd3697.
My own skecth reports:
1.6.1: Lo sketch usa 200.840 byte (38%) dello spazio disponibile per i programmi. Il massimo è 524.288 byte.
1.6.4: Lo sketch usa 243.076 byte (46%) dello spazio disponibile per i programmi. Il massimo è 524.288 byte.
Then I picked the WiFiClient from samples that all of you should have:
1.6.1: Lo sketch usa 195.304 byte (37%) dello spazio disponibile per i programmi. Il massimo è 524.288 byte.
1.6.4: Lo sketch usa 237.576 byte (45%) dello spazio disponibile per i programmi. Il massimo è 524.288 byte.
That's a lot of a difference!
Am I the only one to notice the difference? What's fun is that both compiled versions work.
Hints?
