By manoelps
#26512 [English]
Hello people!
I researched and not found in the forum any related topic.
I need to disable the standby mode ESP-01 (i do not use with the Arduino).
I recorded the example web server that comes in ESP library, but after a few minutes, sometimes seconds, it stops working ... i recorded in LUA and using the IDE arduino, but presents the same problem.
Could someone help me?
[Portuguese]
Olá pessoas!
Eu pesquisei e não encontrei no forum qualquer tópico relacionado.
Eu preciso desativar o modo de espera ESP-01 (eu não uso com o Arduino).
Gravei o servidor web exemplo que me vem na biblioteca ESP, mas depois de alguns minutos, às vezes segundos, ele pára de funcionar ... eu gravei em LUA e usando o Arduino IDE, mas apresenta o mesmo problema.
Alguem pode me ajudar?
By martinayotte
#26528 If your code doesn't explicitly pushing the ESP into deep sleep, it should be alive forever.
Mine is working days after days !
Maybe you have a problem with power supply that make your ESP simply hanging ...
By manoelps
#26560 I'm using the code below for testing.
I'm feeding the USB port of the notebook, I will test with external power.
Thanks for the feedback.
Code: Select all/*
 *  This sketch demonstrates how to set up a simple HTTP-like server.
 *  The server will set a GPIO pin depending on the request
 *    http://server_ip/gpio/0 will set the GPIO2 low,
 *    http://server_ip/gpio/1 will set the GPIO2 high
 *  server_ip is the IP address of the ESP8266 module, will be
 *  printed to Serial when the module is connected.
const char* ssid = "-----------";
const char* password = "-----------";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
  delay(10);
  // prepare GPIO2
  pinMode(2, OUTPUT);
  digitalWrite(2, 0);
  // Connect to WiFi network
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  // Start the server
  server.begin();
  // Print the IP address
  if (!client) {
    return;
  Serial.println("new client");
  while(!client.available()){
    delay(1);
  Serial.println(req);
  client.flush();
  // Match the request
  int val;
  if (req.indexOf("/gpio/0") != -1)
    val = 0;
  else if (req.indexOf("/gpio/1") != -1)
    val = 1;
  else {
    Serial.println("invalid request");
    client.stop();
    return;
  // Set GPIO2 according to the request
  digitalWrite(2, val);
  client.flush();
  // Prepare the response
  String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now ";
  s += (val)?"high":"low";
  s += "</html>\n";
  // Send the response to the client
  client.print(s);
  delay(1);
  Serial.println("Client disonnected");
  // The client will actually be disconnected
  // when the function returns and 'client' object is detroyed
