By Nguyen Anh Tuan
#74295
Stampede wrote:Ah Hah, I see. That makes a whole lot of sense.
I had cut LuaBaz's write script out of my PHP file because I kept getting permissions errors.
I will work on a simple backend storage script, and I will post my solution when I get it running.
Thanks for the links, and the advice. I've been knocking on so many doors looking for that crumb of knowledge!
All the best,
Peter
LauBaz wrote:I have done something similar.
ESP is reading a sensor, connecting to my wifi, connecting to Apache2 webserver on raspberry pi, transmit info, then shut down.
ESP sketch (transmit part):
Code: Select allvoid setup() {
  delay(10);
  //Serial.println();
  Serial.println("");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  WiFiClient client;
  const int httpPort = 8000;
    return;
//temp variable is set with a function to check the temp of an DS18B20 sensor. Let me know if you need it
  String data = "temp1=" + (String)temp;
// "temp1=" is what is going to be sent using GET to the apache server, see code in add.php
  // We now create a URI for the request
  String url = "GET /add.php?" + data + " HTTP/1.1";
client.println(url);
  client.println("Host: 192.168.1.200");
  client.println("Connection: close");
  client.println();
  while(client.available()){
    Serial.print(line);
  client.stop(); //Stopping client
  ESP.deepSleep(60U*60*1000000); //U for unsigned
  delay(1000); //for above sleep
Apache2 to receive data (using GET)
Code: Select all<?php
$date = new DateTime();
$date = $date->format("d-M-Y  h:i:s  ");
if(!empty($_GET["temp1"]))
 $tempesp = "Temperature=";
 $tempesp .= ($_GET["temp1"]);
 file_put_contents("/media/USB/Temp.ESP", $date);
 file_put_contents("/media/USB/Temp.ESP", $tempesp, FILE_APPEND);
echo $tempesp;
I use this so that my server writes the value of temp1, along with a timestamp, to a text file, which I then read with RPI-Monitor to display nice graphs and such.
Hope this helps
Could you send me your project, I really need it
