By lpettipa
#36201 Hello,
Would anyone be able to help me with Arduino IDE code that will work with this board and sensor? I have the attached code, and it kind of works - it prints out 3 accels, but it almost seems like there is a conflict - as the accel will read normal (zero sitting flat), then go to almost 4, then back to around zero....any thoughts? I have the sensor hooked up with no resistors. Power from USB port on my Macbook.
This code works for this sensor with an Arduino UNO - I only made one change for the ESP8266 - seems like "i++" does not work, so I use i=i+1 and x=x+1 in a few spots....
Code: Select all/*
MMA8452Q Basic Example Code
Nathan Seidle
SparkFun Electronics
November 5, 2012
License: This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
This example code shows how to read the X/Y/Z accelerations and basic functions of the MMA5842. It leaves out
all the neat features this IC is capable of (tap, orientation, and inerrupts) and just displays X/Y/Z. See
the advanced example code to see more features.
Hardware setup:
MMA8452 Breakout ------------ Arduino
3.3V --------------------- 3.3V
SDA -------^^(330)^^------- A4
SCL -------^^(330)^^------- A5
GND ---------------------- GND
The MMA8452 is 3.3V so we recommend using 330 or 1k resistors between a 5V Arduino and the MMA8452 breakout.
The MMA8452 has built in pull-up resistors for I2C so you do not need additional pull-ups.
#include <Wire.h> // Used for I2C
// The SparkFun breakout board defaults to 1, set to 0 if SA0 jumper on the bottom of the board is set
#define MMA8452_ADDRESS 0x1D // 0x1D if SA0 is high, 0x1C if lo
//Define a few of the registers that we will be accessing on the MMA8452
#define OUT_X_MSB 0x01
#define XYZ_DATA_CFG 0x0E
#define WHO_AM_I 0x0D
#define CTRL_REG1 0x2A
#define GSCALE 2 // Sets full-scale range to +/-2, 4, or 8g. Used to calc real g values.
void setup()
  Serial.begin(9600);
  Serial.println("MMA8452 Basic Example");
  Wire.begin(); //Join the bus as a master
  initMMA8452(); //Test and intialize the MMA8452
void loop()
  int accelCount[3]; // Stores the 12-bit signed value
  readAccelData(accelCount); // Read the x/y/z adc values
  // Now we'll calculate the accleration value into actual g's
  float accelG[3]; // Stores the real accel value in g's
  for (int i = 0 ; i < 3 ; i=i+1)
    accelG[i] = (float) accelCount[i] / ((1<<12)/(2*GSCALE)); // get actual g value, this depends on scale being set
  // Print out values
    Serial.print(accelG[i], 4); // Print g values
    Serial.print("\t"); // tabs in between axes
  delay(1000); // Delay here for visibility
void readAccelData(int *destination)
  byte rawData[6]; // x/y/z accel register data stored here
  readRegisters(OUT_X_MSB, 6, rawData); // Read the six raw data registers into data array
  // Loop to calculate 12-bit ADC and g value for each axis
  for(int i = 0; i < 3 ; i=i+1)
    int gCount = (rawData[i*2] << 8) | rawData[(i*2)+1]; //Combine the two 8 bit registers into one 12-bit number
    gCount >>= 4; //The registers are left align, here we right align the 12-bit integer
    // If the number is negative, we have to make it so manually (no 12-bit data type)
    if (rawData[i*2] > 0x7F)
      gCount = ~gCount + 1;
      gCount *= -1; // Transform into negative 2's complement #
    destination[i] = gCount; //Record this gCount into the 3 int array
// Initialize the MMA8452 registers
// See the many application notes for more info on setting all of these registers:
// http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MMA8452Q
void initMMA8452()
  byte c = readRegister(WHO_AM_I); // Read WHO_AM_I register
  if (c == 0x2A) // WHO_AM_I should always be 0x2A
    Serial.println("MMA8452Q is online...");
  else
    Serial.print("Could not connect to MMA8452Q: 0x");
    Serial.println(c, HEX);
    while(1) ; // Loop forever if communication doesn't happen
  MMA8452Standby(); // Must be in standby to change registers
  // Set up the full scale range to 2, 4, or 8g.
  byte fsr = GSCALE;
  if(fsr > 8) fsr = 8; //Easy error check
  fsr >>= 2; // Neat trick, see page 22. 00 = 2G, 01 = 4A, 10 = 8G
  writeRegister(XYZ_DATA_CFG, fsr);
  //The default data rate is 800Hz and we don't modify it in this example code
  MMA8452Active(); // Set to active to start reading
// Sets the MMA8452 to standby mode. It must be in standby to change most register settings
void MMA8452Standby()
  byte c = readRegister(CTRL_REG1);
  writeRegister(CTRL_REG1, c & ~(0x01)); //Clear the active bit to go into standby
// Sets the MMA8452 to active mode. Needs to be in this mode to output data
void MMA8452Active()
  writeRegister(CTRL_REG1, c | 0x01); //Set the active bit to begin detection
// Read bytesToRead sequentially, starting at addressToRead into the dest byte array
void readRegisters(byte addressToRead, int bytesToRead, byte * dest)
  Wire.beginTransmission(MMA8452_ADDRESS);
  Wire.write(addressToRead);
  Wire.endTransmission(false); //endTransmission but keep the connection active
  Wire.requestFrom(MMA8452_ADDRESS, bytesToRead); //Ask for bytes, once done, bus is released by default
  while(Wire.available() < bytesToRead); //Hang out until we get the # of bytes we expect
  for(int x = 0 ; x < bytesToRead ; x=x+1)
    dest[x] = Wire.read();
// Read a single byte from addressToRead and return it as a byte
byte readRegister(byte addressToRead)
  Wire.requestFrom(MMA8452_ADDRESS, 1); //Ask for 1 byte, once done, bus is released by default
  while(!Wire.available()) ; //Wait for the data to come back
  return Wire.read(); //Return this one byte
// Writes a single byte (dataToWrite) into addressToWrite
void writeRegister(byte addressToWrite, byte dataToWrite)
  Wire.write(addressToWrite);
  Wire.write(dataToWrite);
  Wire.endTransmission(); //Stop transmitting
By lpettipa
#36520 So for anyone this may help:
I have not been able to solve the original problem (getting the Sparkfun MMA8452 accel sensor to work with ESP8266). But, I've switched to Adafruit's ADXL345, used the library off the tutorial page, and it works perfect.
Please ignor the i++ / i=i+1 stuff in my previous post, I was doing something wrong.
I also tried the alternate i2c address for the MMA8452, nothing changed.
By lpettipa
#36713 Ok, got the MMA8452 accel sensor working with the ESP8266 Thing Dev from Sparkfun. Really basic issue - I thought the microcontroller logic was 3.3v....I was confused, as Sparkfun offers a very similar board, which I thought was the one I ordered....so on this one, the logic is at 5V (checked with my meter)- added some 470 ohm resistors to the i2c lines - works perfect now.
So this older code below is working (code from sparkfun's website will not compile....):
Can someone put this in the ESP8266 Arduino library so others can have access to it?
Code: Select all/*
Nathan Seidle
November 5, 2012
Hardware setup:
#define MMA8452_ADDRESS 0x1C // 0x1D if SA0 is high, 0x1C if lo
void setup()
  Serial.begin(9600);
void loop()
  for (int i = 0 ; i < 3 ; i++)
  // Print out values
yield();
  for(int i = 0; i < 3 ; i++)
yield();
void initMMA8452()
  else
  byte fsr = GSCALE;
  for(int x = 0 ; x < bytesToRead ; x++)
