By Arduolli
#41748
martinayotte wrote:Unfortunately, we need to see more of your ESP code.
But I think the issue is that you are leaving the client opened, it should be close it and reconnect new client for each transmission.
Also, BTW, I see that you are sending all the 10 timestamps on the same line, you should at least add a separator such a comma or space between each.
Hi martinayotte; thanks for your feedback.
I know that I am missing commas or similar - these got lost during trial and error hunting....
Also, I am not sure about the closing issue, as I send packets of ten - and for each packet the last is received.....
Here is the entire code - I hope this helps to nail it down - thanks again:
Code: Select all#include <Bounce2.h>
#include <Time.h>
#define REED_PIN 2
#define loopmaxcount 10
const char* ssid = "xxxxxxx";
const char* password = "xxxxxx";
const char* host = "xxxxxx";
int GasCounter = 0;   // counter; 1 equals 0,01 m3
int timestamp[loopmaxcount];      // time stamp array for sending batches of #[loopmaxcount] to server
// Instantiate a Bounce object
Bounce debouncer = Bounce();
  delay(10);
  // prepare GPIO2
  pinMode(REED_PIN, INPUT_PULLUP);
  // connect to WiFi
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
   // After setting up the reed-switch, setup the Bounce instance :
  debouncer.attach(REED_PIN);
  debouncer.interval(50); // interval in ms
int value = 0;
  for(int x = 0;x < loopmaxcount; x++) {  // accumulate batch of timestamps
    // Update the Bounce instance :
    debouncer.update();
    // compare the reedState to its previous state
    if (debouncer.fell()) {
      ++GasCounter;
      Serial.println(GasCounter);
      timestamp[x]=now();
    else {
      x--;
  //  yield();
   delay(100);
 delay(5000);
  ++value;
  Serial.println(host);
  WiFiClient client;
  const int Port = 9999;
  if (!client.connect(host, Port)) {
    return;
  // This will send the data to the server
 for(int x = 0;x < loopmaxcount; x++) {  // send batch of timestamps server
    client.println(timestamp[x]);
  //    client.println();
  delay(10);
  while (client.available()) {
    Serial.print(line);
By martinayotte
#41750 Ok ! I think I found out !
Doing single client.println() is known to start packet sending right away, not waiting a WiFi buffer been full.
So, it is better to optimize data to be sent in a single string to be sent with only one client.println().
Code: Select allString s = "";
    s += String(timestamp[x]) + "\n";
client.print(s);
By Arduolli
#41752
martinayotte wrote:Ok ! I think I found out !
client.print(s);
GREAT!
Thank you so much - this works!
Have a good evening.
