By costo
#40516 Thank you very much for your help.
In the meantime I have added this function in my sketch (without the ....... dots) and also added the command
user_init();
as first line in the setup.
Sketch compiles and I flash it but sadly I still get all outputs from Serial.print functions to the normal Rx and Tx .
So there is something more going on which I do not understand :(
edit: also tried it the way exactly as you supposed but that gives me the same result.
By martinayotte
#40526 BTW, I'm seeing that the ArduinoESP core has integrate Serial.swap(), so you can try it out instead of using the plain SDK alternate function.
It should be something like :
Code: Select allSerial.swap(15); //toggle between use of GPIO13/GPIO15 or GPIO3/GPIO(1/2) as RX and TX
