#include "DHT.h"
#define DHTPIN 2
#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
DHT dht(DHTPIN, DHTTYPE);
void getSensorData();
Serial.begin(9600);
pinMode(DHTPIN, INPUT_PULLUP);
dht.begin();
Serial.println("Woke up!");
// Wait a few seconds between measurements.
delay(5000);
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
return;
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(t);
Serial.print(" *C ");
// try the an other methode ..
getSensorData();
Serial.println("Sleep now!");
//delay(20 * 1000); // Send data every 20 seconds
ESP.deepSleep(0.1 * 60000000); // Send to sleep for 35 minutes
void getSensorData() {
int retry_limit = 50; // Limit read attempts.
float temperature = dht.readTemperature();
float humidity = dht.readHumidity();
while ((isnan(temperature) || isnan(humidity))
|| (temperature == 0 && humidity == 0)) {
if (--retry_limit < 1) {
temperature = -1;
humidity = -1;
Serial.println(F("No DHT sensor detected."));
return;
#ifdef DEBUG
RFlash();
Serial.print(F("!"));
#endif
delay(5000);
#ifdef DEBUG
Serial.println("");
RFlash();
#endif
}And that's the result
0�~�4�!�{�OAa�Woke up!
Humidity: 47.20 % Temperature: 21.10 *C Sleep now!
0�~?�4�!�{�OA,�Woke up!
Woke up!
Woke up!
Woke up!
Woke up!
Woke up!
Woke up!
I am unable to read data from the dht22, even if I loop through the sensor reading.
