I've got the original open source script for the deauth detecter and it has the 'Pirates of the Caribbean' theme song that plays on the buzzer when an attack is detected. I want the "Imperial March" song from Star Wars to play instead but I'm having issues with certain declarations when I compile it.
Basically I need help smashing the two scripts together.
Here is the original deauth detecter .ino:
// This software is licensed under the MIT License.
// See the license file for details.
// For more details visit github.com/spacehuhn/DeauthDetector
// include necessary libraries
#include <ESP8266WiFi.h> // For the WiFi Sniffer
#include <Adafruit_NeoPixel.h> // For the Neopixel/WS2812 LED(s)
// include ESP8266 Non-OS SDK functions
extern "C" {
#include "user_interface.h"
// ===== SETTINGS ===== //
#define LED 4 /* LED pin */
#define LED_NUM 1 /* Number of LEDs */
#define BUZZER 5 /* Buzzer pin */
#define SPEED 1.5 /* Song speed, the bigger the number the slower the song */
#define SERIAL_BAUD 115200 /* Baudrate for serial communication */
#define CH_TIME 140 /* Scan time (in ms) per channel */
#define PKT_RATE 5 /* Min. packets before it gets recognized as an attack */
#define PKT_TIME 1 /* Min. interval (CH_TIME*CH_RANGE) before it gets recognized as an attack */
// Channels to scan on (US=1-11, EU=1-13, JAP=1-14)
const short channels[] { 1,2,3,4,5,6,7,8,9,10,11,12,13/*,14*/ };
// ===== Runtime variables ===== //
Adafruit_NeoPixel pixels { LED_NUM, LED, NEO_GRB + NEO_KHZ800 }; // Neopixel LEDs
bool song_playing { false }; // If a song is currently playing
int note_index { 0 }; // Index of note that is currently playing
int note_time { 0 }; // The amount of time (ms) a note is played
int ch_index { 0 }; // Current index of channel array
int packet_rate { 0 }; // Deauth packet counter (resets with each update)
int attack_counter { 0 }; // Attack counter
unsigned long update_time { 0 }; // Last update time
unsigned long ch_time { 0 }; // Last channel hop time
unsigned long song_time { 0 }; // Last song update
// ===== Notes ===== //
// Borrowed with <3 from here: https://github.com/xitangg/-Pirates-of- ... Theme-Song
#define NOTE_C4 262
#define NOTE_D4 294
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_G4 392
#define NOTE_A4 440
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_D5 587
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_G5 784
#define NOTE_A5 880
#define NOTE_B5 988
int notes[] {
NOTE_E4, NOTE_G4, NOTE_A4, NOTE_A4, 0,
NOTE_A4, NOTE_B4, NOTE_C5, NOTE_C5, 0,
NOTE_C5, NOTE_D5, NOTE_B4, NOTE_B4, 0,
NOTE_A4, NOTE_G4, NOTE_A4, 0,
NOTE_A4, NOTE_C5, NOTE_D5, NOTE_D5, 0,
NOTE_D5, NOTE_E5, NOTE_F5, NOTE_F5, 0,
NOTE_E5, NOTE_D5, NOTE_E5, NOTE_A4, 0,
NOTE_A4, NOTE_C5, NOTE_B4, NOTE_B4, 0,
NOTE_C5, NOTE_A4, NOTE_B4, 0,
NOTE_A4, NOTE_A4,
NOTE_E5, 0, 0, NOTE_F5, 0, 0,
NOTE_E5, NOTE_E5, 0, NOTE_G5, 0, NOTE_E5, NOTE_D5, 0, 0,
NOTE_D5, 0, 0, NOTE_C5, 0, 0,
NOTE_B4, NOTE_C5, 0, NOTE_B4, 0, NOTE_A4,
int duration[] {
125, 125, 250, 125, 125,
125, 125, 375, 125,
125, 125, 375, 125,
125, 125, 125, 250, 125,
250, 125, 250, 125,
125, 125, 375, 375,
250, 125,
125, 125, 375, 125,
125, 125, 375, 125,
250, 125, 250, 125,
125, 125, 375, 375,
250, 125, 375, 250, 125, 375,
125, 125, 125, 125, 125, 125, 125, 125, 375,
125, 125, 125, 125, 125, 500,
// ===== Sniffer function ===== //
void sniffer(uint8_t *buf, uint16_t len) {
if (!buf || len < 28) return; // Drop packets without MAC header
byte pkt_type = buf[12]; // second half of frame control field
//byte* addr_a = &buf[16]; // first MAC address
//byte* addr_b = &buf[22]; // second MAC address
// If captured packet is a deauthentication or dissassociaten frame
if (pkt_type == 0xA0 || pkt_type == 0xC0) {
++packet_rate;
// ===== Attack detection functions ===== //
void attack_started() {
song_playing = true;
note_index = 0;
note_time = duration[note_index] * SPEED;
for(int i=0; i<LED_NUM; ++i)
pixels.setPixelColor(i, pixels.Color(120,0,0));
pixels.show();
Serial.println("ATTACK DETECTED");
void attack_stopped() {
song_playing = false;
noTone(BUZZER); // Stop playing
pixels.setPixelColor(i, pixels.Color(0,100,0));
pixels.show();
Serial.println("ATTACK STOPPED");
// ===== Setup ===== //
Serial.begin(SERIAL_BAUD); // Start serial communication
// Init LEDs
pixels.begin();
pixels.show();
pinMode(BUZZER, OUTPUT); // Init buzzer pin
WiFi.disconnect(); // Disconnect from any saved or active WiFi connections
wifi_set_opmode(STATION_MODE); // Set device to client/station mode
wifi_set_promiscuous_rx_cb(sniffer); // Set sniffer function
wifi_set_channel(channels[0]); // Set channel
wifi_promiscuous_enable(true); // Enable sniffer
Serial.println("Started \\o/");
// ===== Loop ===== //
unsigned long current_time = millis(); // Get current time (in ms)
// Update each second (or scan-time-per-channel * channel-range)
if (current_time - update_time >= (sizeof(channels)*CH_TIME)) {
update_time = current_time; // Update time variable
// When detected deauth packets exceed the minimum allowed number
if (packet_rate >= PKT_RATE) {
++attack_counter; // Increment attack counter
} else {
if(attack_counter >= PKT_TIME) attack_stopped();
attack_counter = 0; // Reset attack counter
// When attack exceeds minimum allowed time
if (attack_counter == PKT_TIME) {
attack_started();
Serial.print("Packets/s: ");
Serial.println(packet_rate);
packet_rate = 0; // Reset packet rate
// Channel hopping
if (sizeof(channels) > 1 && current_time - ch_time >= CH_TIME) {
ch_time = current_time; // Update time variable
// Get next channel
ch_index = (ch_index+1) % (sizeof(channels)/sizeof(channels[0]));
short ch = channels[ch_index];
// Set channel
//Serial.print("Set channel to ");
//Serial.println(ch);
wifi_set_channel(ch);
if(song_playing && current_time - song_time >= note_time) {
song_time = current_time;
note_index = (note_index+1) % (sizeof(notes)/sizeof(notes[0]));
tone(BUZZER, notes[note_index], note_time);
And here is the Star Wars song .ino:
const int c = 261;
const int d = 294;
const int e = 329;
const int f = 349;
const int g = 391;
const int gS = 415;
const int a = 440;
const int aS = 455;
const int b = 466;
const int cH = 523;
const int cSH = 554;
const int dH = 587;
const int dSH = 622;
const int eH = 659;
const int fH = 698;
const int fSH = 740;
const int gH = 784;
const int gSH = 830;
const int aH = 880;
const int buzzerPin = 5;
const int ledPin1 = 12;
const int ledPin2 = 13;
int counter = 0;
void setup()
//Setup pin modes
pinMode(buzzerPin, OUTPUT);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
void loop()
//Play first section
firstSection();
//Play second section
secondSection();
//Variant 1
beep(f, 250);
beep(gS, 500);
beep(f, 350);
beep(a, 125);
beep(cH, 500);
beep(a, 375);
beep(cH, 125);
beep(eH, 650);
//Repeat second section
secondSection();
//Variant 2
beep(f, 250);
beep(gS, 500);
beep(f, 375);
beep(cH, 125);
beep(a, 500);
beep(f, 375);
beep(cH, 125);
beep(a, 650);
delay(650);
void beep(int note, int duration)
//Play tone on buzzerPin
tone(buzzerPin, note, duration);
//Stop tone on buzzerPin
noTone(buzzerPin);
delay(50);
//Increment counter
counter++;
void firstSection()
beep(a, 500);
beep(a, 500);
beep(a, 500);
beep(f, 350);
beep(cH, 150);
beep(a, 500);
beep(f, 350);
beep(cH, 150);
beep(a, 650);
beep(eH, 500);
beep(eH, 500);
beep(eH, 500);
beep(fH, 350);
beep(cH, 150);
beep(gS, 500);
beep(f, 350);
beep(cH, 150);
beep(a, 650);
void secondSection()
beep(aH, 500);
beep(a, 300);
beep(a, 150);
beep(aH, 500);
beep(gSH, 325);
beep(gH, 175);
beep(fSH, 125);
beep(fH, 125);
beep(fSH, 250);
delay(325);
beep(aS, 250);
beep(dSH, 500);
beep(dH, 325);
beep(cSH, 175);
beep(cH, 125);
beep(b, 125);
beep(cH, 250);
delay(350);
