Nodemcu port forwarding
Posted: Mon Mar 22, 2021 6:25 am
Hello Dears
I have a Static IP service.I want to forward the nodemcu port for access from outside the local network and through the internet.I designed a form and a uint or int variable (uint port;) and I intend to use eeprom to store it. Apparently everything is fine, but when the variable I put front the ESP8266WebServer (ESP8266WebServer server(port);), it receives IP from the router, but I do not have access to the root with the port contract after the IP (192.168.1.10:90) in the browser, while if I Put any other number in place of the variable, it will work without any problem!!!
How I can fix this problem?
Sorry about my bad english.
https://imgur.com/JLxFGNm
https://imgur.com/gpbdHos
https://imgur.com/AQVNCS9
https://imgur.com/iBQN9fd
#define ONE_WIRE_BUS D3
#include <Wire.h>
#include <LiquidCrystal_I2C.h> //D1&D2
#include <DallasTemperature.h>
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature DS18B20(&oneWire);
#include <SHT1x.h>
#define dataPin 14 //data s3
#define clockPin 12 //cloc s1
SHT1x sht1x(dataPin, clockPin);
#include <EEPROM.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#define HEATER D7
#define STEAM D8
#include <RtcDS1307.h>
RtcDS1307<TwoWire> Rtc(Wire);
byte termometer[8] = //icon for termometer
B00100,
B01010,
B01010,
B01110,
B01110,
B11111,
B11111,
B01110
byte droplet[8] = //icon for water droplet
B00100,
B00100,
B01010,
B01010,
B10001,
B10001,
B10001,
B01110,
byte Degree[8] = //icon for Degree
B01110,
B01010,
B01110,
B00000,
B00110,
B01000,
B01000,
B00110
byte mini[8] = //icon for minimum
B01110,
B01110,
B01110,
B01110,
B11111,
B11111,
B01110,
B00100
byte maxi[8] = //icon for maximum
B00100,
B01110,
B11111,
B11111,
B01110,
B01110,
B01110,
B01110
const char* ssid = "DALI_CHA";
const char* password = "";
float getTemperature() {
float Temp;
do {
DS18B20.requestTemperatures();
Temp = DS18B20.getTempCByIndex(0);
delay(100);
} while (Temp == 85.0 || Temp == (-127.0));
return Temp;
float Temp;
float Humidity;
int heatmin=0;
int heatmax=0;
int humimin=0;
int humimax=0;
int maxTemp =-100;
int minTemp=100;
int maxHumidity =-100;
int minHumidity=100;
int firstdigit;
int firstdigit2;
uint port;
void setupe()
EEPROM.begin(1024);
port=EEPROM.read(5);
EEPROM.end();
const char root [] =
"<!DOCTYPE HTML>\n"
"<title>DALI CHAI MONITORING</title>\n"
"<body bgcolor=\"black\">\n"
"<font face=\"Arial Black\">\n"
"<table style=\"height: 100%; margin-left: auto; margin-right: auto;\" width=\"100%;\">\n"
"<tbody>\n"
"<tr style=\"height: 100%;\">\n"
"<td style=\"width: 100%; height: 100%;\">\n"
"<h1 style=\"text-align: center;\"><span style=\"color: #ffff00;\">WELCOME TO DALI CHAI SMART FARM WIFI</span></h1>\n"
"<hr /></td>\n"
"</tr>\n"
"<td style=\"width: 100%; height: 100%; text-align: center;\">\n"
"<h2><a href=/view><span style=\"color: #ffff00;\">Sensor Data</span></a></h2>\n"
"<h2><a href=/setting><span style=\"color: #ffff00;\">Setting</span></a></h2>\n"
"<h2><span style=\"color: #ffff00;\">About</span></h2>\n"
"<h2><span style=\"color: #ffff00;\">Contact</span></h2>\n"
"<hr /></td>\n"
"</tr>\n"
"<h4 style=\"text-align: center;\"><span style=\"color: #ffff00;\"><span id=\"result_box\" class=\"\" lang=\"en\"><span class=\"\">This page is designed using open source software and belongs to Mehr 15 Abhar CO-OP.</span></span></span></h4>\n"
"</td>\n"
"</tr>\n"
"</tbody>\n"
"</table>\n"
"<p> </p>\n"
"</font>\n"
"</body>\n"
"</html>\n";
const char set [] =
"<!DOCTYPE HTML>"
"<html>"
"<head>"
"<meta name = \"viewport\" content = \"width = device-width, initial-scale = 1.0, maximum-scale = 1.0, user-scalable=0\">"
"<title>Setting</title>"
"<style>"
"\"body { background-color: #808080; font-family: Arial, Helvetica, Sans-Serif; Color: #000000; }\""
"</style>"
"</head>"
"<body>"
"<h1>Setting</h1>"
"<FORM name=Form1 action=\"/setting\" method=\"post\">"
"<P>"
"Enter Min T:<input name=\"Hheatmin\"type=\"number\"><BR>"
"Enter Max T:<input name=\"Hheatmax\"type=\"number\"><BR>"
"Enter Min H:<input name=\"Hhumimin\"type=\"number\"><BR>"
"Enter Max H:<input name=\"Hhumimax\"type=\"number\"><BR>"
"<INPUT type=\"submit\" value=\"Send\" return fals;>"
"</P>"
"</FORM>"
"<FORM action=\"/setting\" method=\"post\">"
"<P>"
"<INPUT type=\"radio\" name=\"rest\" value=\"1\">Rest MIN & MAX<BR>"
"<INPUT type=\"submit\" value=\"Send\">"
"</P>"
"</FORM>"
"<FORM name=Form2 action=\"/setting\" method=\"post\">"
"<P>"
"Enter local port:<input name=\"Hport\"type=\"number\"><BR>"
"</P>"
"</FORM>"
"<a href=\"/\">Main menu</a>""<br>"
"</body>"
"</html>";
LiquidCrystal_I2C lcd(0x3F,20,4);
void setup()
Serial.begin(9600);
EEPROM.begin(1024);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
server.begin();
server.on("/",handleRoot);
server.on("/setting",handleset);
server.on("/view",handleview);
server.on("/view/advance",handleadvance);
Wire.pins(D2,D1);
lcd.begin();
lcd.createChar(1,termometer);
lcd.createChar(2,droplet);
lcd.createChar(3,Degree);
lcd.createChar(4,mini);
lcd.createChar(5,maxi);
heatmin=EEPROM.read(1);
heatmax=EEPROM.read(2);
humimin=EEPROM.read(3);
humimax=EEPROM.read(4);
pinMode(HEATER,OUTPUT);
pinMode(STEAM,OUTPUT);
//------------------------------- Rtc ----------------------------------
lcd.clear();
lcd.setCursor(0, 0);
lcd.write(1);
lcd.write(2);
lcd.setCursor(18,0);
lcd.write(2);
lcd.write(1);delay(500);
lcd.setCursor(2,0);
lcd.print("DALI CHAI SERISE");delay(500);
lcd.setCursor(0,1);
lcd.print("Smart Farme WIFI WEB");delay(750);
lcd.setCursor(0,2);
lcd.print("KEYLES IP&WEB CONFIG");delay(750);
lcd.setCursor(0,3);
lcd.print("MEHR 15 ABHAR V99.1");delay(1000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Please Wait ");delay(500);
lcd.print(".");delay(500);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("RTC:");
lcd.setCursor(0,1);
lcd.print("WEB SERVER:");
lcd.setCursor(0,2);
lcd.print("DS18B20:");
lcd.setCursor(0,3);
lcd.print("SHT10:");delay(500);
lcd.setCursor(13,0);
lcd.print("started");delay(500);
lcd.setCursor(13,1);
lcd.setCursor(13,2);
lcd.setCursor(13,3);
lcd.clear();
//------------------------------- HTML CODE ----------------------------------
void handleRoot()
server.send(200, "text/html", root);
void returnFail(String msg)
server.sendHeader("Connection", "close");
server.sendHeader("Access-Control-Allow-Origin", "*");
server.send(500, "text/plain", msg + "\r\n");
void handleset()
if (server.hasArg("Hheatmin")) {
handleSubmit();
else if (server.hasArg("rest")) {
handleSubmit2();
else if (server.hasArg("Hport")) {
handleSubmit3();
else {
server.send(200, "text/html", set);
void handleSubmit()
if (!server.hasArg("Hheatmin")) return returnFail("BAD ARGS");
heatmin=server.arg("Hheatmin").toInt();{EEPROM.put(1,heatmin);EEPROM.commit();}
if (!server.hasArg("Hheatmax")) return returnFail("BAD ARGS");
heatmax=server.arg("Hheatmax").toInt();{EEPROM.put(2,heatmax);EEPROM.commit();}
if (!server.hasArg("Hhumimin")) return returnFail("BAD ARGS");
humimin=server.arg("Hhumimin").toInt();{EEPROM.put(3,humimin);EEPROM.commit();}
if (!server.hasArg("Hhumimax")) return returnFail("BAD ARGS");
humimax=server.arg("Hhumimax").toInt();{EEPROM.put(4,humimax);EEPROM.commit();}
void handleSubmit2()
String restvalue;
if (!server.hasArg("rest")) return returnFail("BAD ARGS");
restvalue = server.arg("rest");
if (restvalue == "1") {
maxTemp=Temp;
minTemp=Temp;
maxHumidity =Humidity;
minHumidity=Humidity;
server.send(200, "text/html",set);
else {
returnFail("Fail");
void handleSubmit3()
if (port==0)
{port=80;}
if (!server.hasArg("Hport")) return returnFail("BAD ARGS");
port=server.arg("Hport").toInt();{EEPROM.put(5,port);EEPROM.commit();}
EEPROM.end();
void handleview()
String cssClass = "mediumhot";
if (Temp < heatmin)
cssClass = "cold";
else if (Temp > heatmax)
cssClass = "hot";
String view = "<!DOCTYPE html><html><head><title>""Summary Sensor Data""</title><meta charset=\"utf-8\" /><meta name=\"viewport\" content=\"width=device-width\" /><style>\n";
view += "html {height: 100%;}";
view += "div {color: #fff;font-family: 'Arial Black';font-weight: 400;left: 50%;position: absolute;text-align: center;top: 50%;transform: translateX(-50%) translateY(-50%);}";
view += "h1 {font-size: large;font-weight: 400; margin: 0}";
view += "h2 {font-size: 80%;font-weight: 400; margin: 0}";
view += "h3 {font-size: 60%;font-weight: 400; margin: 0}";
view += "body {height: 100%;}";
view += ".cold {background: linear-gradient(to bottom, #7abcff, #0665e0 );}";
view += ".mediumhot {background: linear-gradient(to bottom, #81ef85,#057003);}";
view += ".hot {background: linear-gradient(to bottom, #fcdb88,#d32106);}";
view += "</style></head><body class=\"" + cssClass + "\"><div>"
"<h1>"+WiFi.localIP().toString()+"</h1>""<br>"
"<h2>""T : "+Temp +"°C""<br></h2>"
"<h2>""H : "+Humidity +"%""<br></h2>""<br>";
view +="<h3>""<a href=\"/view/advance\">Advance</a>""<br>";
view +="<a href=\"/\">Main menu</a>""</h3>""</div></body></html>";
view +=("<meta http-equiv=\"refresh\" content=\"10\">");
server.send(200, "text/html", view);
void handleadvance()
if (Temp < heatmin)
cssClass = "cold";
cssClass = "hot";
String advance = "<!DOCTYPE html><html><head><title>""Advance Sensor Data""</title><meta charset=\"utf-8\" /><meta name=\"viewport\" content=\"width=device-width\" /><style>\n";
advance += "html {height: 100%;}";
advance += "div {color: #fff;font-family: 'Arial Black';font-weight: 400;left: 50%;position: absolute;text-align: center;top: 50%;transform: translateX(-50%) translateY(-50%);}";
advance += "h1 {font-size: large;font-weight: 400; margin: 0}";
advance += "h2 {font-size: 80%;font-weight: 400; margin: 0}";
advance += "h3 {font-size: 60%;font-weight: 400; margin: 0}";
advance += "h4 {font-size: 40%;font-weight: 400; margin: 0}";
advance += "body {height: 100%;}";
advance += ".cold {background: linear-gradient(to bottom, #7abcff, #0665e0 );}";
advance += ".mediumhot {background: linear-gradient(to bottom, #81ef85,#057003);}";
advance += ".hot {background: linear-gradient(to bottom, #fcdb88,#d32106);}";
advance += "</style></head><body class=\"" + cssClass + "\"><div>"
"<h3>""Max Temperature : "+maxTemp+"°C"+"<br>"
"Min Temperature : "+minTemp+"°C""<br>"
+"Set Min Temperature : "+heatmin+"°C""<br>"
+"Set Max Temperature : "+heatmax+"°C""</h3>""<br>"
"<h3>""Max Humidity : "+maxHumidity+"%"+"<br>"
"Min Humidity : "+minHumidity+"%""<br>"
+"Set Min Humidity : "+humimin+"%""<br>"
+"Set Max Humidity : "+humimax+"%""</h3>""<br>";
advance +="<h4>""<a href=\"/view\">Summary</a>""<br>";
advance +="<a href=\"/\">Main menu</a>""</h4>""</div></body></html>";
advance +=("<meta http-equiv=\"refresh\" content=\"10\">");
server.send(200, "text/html",advance);
Temp = getTemperature();
Humidity = sht1x.readHumidity();
if (Temp<minTemp){minTemp = Temp;}
if (Temp>maxTemp){maxTemp = Temp;}
if (Humidity<minHumidity){minHumidity= Humidity;}
if (Humidity>maxHumidity){maxHumidity = Humidity;}
//----------------------------- Relay Control -----------------------------------
if ( Temp < heatmin ) digitalWrite(HEATER,HIGH);
if ( Temp > heatmax and Temp > heatmin ) digitalWrite(HEATER,LOW);
if ( Humidity < humimin ) digitalWrite(STEAM,HIGH);
if ( Humidity > humimax and Temp > humimin ) digitalWrite(STEAM,LOW);
//---------------------------- LCD ----------------------------------------------
lcd.write(1);
lcd.setCursor(2, 0);
lcd.print(Temp,2);
lcd.setCursor(7, 0);
lcd.write(3);
lcd.setCursor(9, 0);
lcd.write(5);
lcd.setCursor(10, 0);
lcd.print(maxTemp);
lcd.setCursor(13, 0);
lcd.write(4);
lcd.setCursor(14, 0);
lcd.print(minTemp);
lcd.setCursor(17, 0);
lcd.print("R:");
lcd.setCursor(19, 0);
if (digitalRead(HEATER)==HIGH){lcd.setCursor(19, 0);lcd.print("H");}
else {lcd.setCursor(19, 0);lcd.print("L");}
lcd.setCursor(0,1);
lcd.write(2);
lcd.setCursor(2, 1);
lcd.print(Humidity,2);
lcd.setCursor(7, 1);
lcd.print("%");
lcd.setCursor(9, 1);
lcd.write(5);
lcd.setCursor(10, 1);
lcd.print(maxHumidity);
lcd.setCursor(13, 1);
lcd.write(4);
lcd.setCursor(14, 1);
lcd.print(minHumidity);
lcd.setCursor(17, 1);
lcd.print("R:");
lcd.setCursor(19, 1);
if (digitalRead(STEAM)==HIGH){lcd.setCursor(19, 1);lcd.print("H");}
else {lcd.setCursor(19, 1);lcd.print("L");}
lcd.setCursor(0, 2);
lcd.print("ST:");
lcd.setCursor(3, 2);
lcd.print(heatmin);
if (heatmin < 100 && heatmin > 0 ){lcd.setCursor(5, 2);lcd.print(" ");}
if (heatmin < 10 && heatmin > 0 ){lcd.setCursor(4, 2);lcd.print(" ");}
if (heatmin == 0 ){lcd.setCursor(4, 2);lcd.print(" ");}
lcd.setCursor(6, 2);
lcd.print("/");
lcd.setCursor(7, 2);
lcd.print(heatmax);
if (heatmax < 100 && heatmax > 0 ){lcd.setCursor(9, 2);lcd.print(" ");}
if (heatmax < 10 && heatmax > 0 ){lcd.setCursor(8, 2);lcd.print(" ");}
if (heatmax == 0 ){lcd.setCursor(8, 2);lcd.print(" ");}
lcd.setCursor(12, 2);
lcd.print("SH:");
lcd.setCursor(15, 2);
lcd.print(firstdigit);
if (humimin < 100)firstdigit = humimin;
else if (humimin < 1000)firstdigit = humimin / 10;
if (humimax < 10 && heatmax > 0 ){lcd.setCursor(16, 2);lcd.print(" ");}
lcd.setCursor(17, 2);
lcd.print("/");
lcd.setCursor(18, 2);
lcd.print(firstdigit2);
if (humimax < 100)firstdigit2 = humimax;
else if (humimax < 1000)firstdigit2 = humimax / 10;
if (humimax < 10 && heatmax > 0 ){lcd.setCursor(19, 2);lcd.print(" ");}
lcd.setCursor(0, 3);
lcd.print(WiFi.localIP());
WiFiClient client;
if (WiFi.localIP()==!WiFi.status()){lcd.setCursor(0, 3);lcd.print("Disconnected ");}
else {lcd.setCursor(0, 3);lcd.print(WiFi.localIP());}
lcd.setCursor(15, 3);
lcd.print(port);
server.handleClient();
