- baud rate: 115200
- Board: Generic ESP8266 Model
- port is correct: COM4
- hardware is fine because this works on my older computer.
I have tried downgrading to different versions of esp8266 boards with no luck.
Here is the error...
esptool.py v3.0
Serial port COM4
Connecting...
File "C:\Users\justi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.0/tools/upload.py", line 66, in <module>
esptool.main(cmdline)
File "C:/Users/justi/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/esptool\esptool.py", line 3552, in main
esp.connect(args.before, args.connect_attempts)
File "C:/Users/justi/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/esptool\esptool.py", line 519, in connect
last_error = self._connect_attempt(mode=mode, esp32r0_delay=False)
File "C:/Users/justi/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/esptool\esptool.py", line 499, in _connect_attempt
self.sync()
File "C:/Users/justi/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/esptool\esptool.py", line 438, in sync
timeout=SYNC_TIMEOUT)
File "C:/Users/justi/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/esptool\esptool.py", line 376, in command
self.write(pkt)
File "C:/Users/justi/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/esptool\esptool.py", line 339, in write
self._port.write(buf)
File "C:/Users/justi/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.0/tools/pyserial\serial\serialwin32.py", line 325, in write
raise SerialTimeoutException('Write timeout')
serial.serialutil.SerialTimeoutException: Write timeout
the selected serial port serial.serialutil.SerialTimeoutException: Write timeout
does not exist or your board is not connected
