74880 is fast enough for most comms, and I now use it as my standard rate. Can we have 74880 supported by the Arduino IDE.
Pretty Please.
Explore... Chat... Share...
I think his idea was to use one consistent baud rate so you can see the bootloader messages as well as anything from your software
ets Jan 8 2013,rst cause:1, boot mode:(3,7)
load 0x40100000, len 25336, room 16
tail 8
chksum 0x1f
load 0x3ffe8000, len 2544, room 0
tail 0
chksum 0xb8
load 0x3ffe89f0, len 1044, room 8
tail 12
chksum 0x7f
csum 0x7f ets Jan 8 2013,rst cause:2, boot mode:(3,6)It takes about 20-25 seconds for home assistant c[…]
