#if 0
in c_types.h that needed to be changed! That's a stupid trap...
Explore... Chat... Share...
Moderator: Sprite_tm
Closed 0x3fff7d50, took 291ms, heap=13168
6367> Closed 0x3fff8518, took 236ms, heap=15048
6441> Closed 0x3fff7b60, took 445ms, heap=17408
6560> GET /home.tpl (0x3fff7a28) 10.42.0.1:45646
6698> Closed 0x3fff7a28, took 152ms, heap=17232
6774> GET /pure-min.css (0x3fff7e90) 10.42.0.1:45647
6827> Fatal exception (28):
6827> epc1=0x4020c9e4, epc2=0x00000000, epc3=0x00000000, excvaddr=0x0000000c, depc=0x00000000
ets Jan 8 2013,rst cause:4, boot mode:(3,0)
wdt reset
load 0x40100000, len 1396, room 16
tail 4
chksum 0x89
load 0x3ffe8000, len 776, room 4
tail 4
chksum 0xe8
load 0x3ffe8308, len 540, room 4
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size & Map: 4Mbit(256KB+256KB)
jump to run user1 @ 1000
rl�
Initializing esp-link
esp-link 0.10.0 - 2015-06-19 14:16:00 - f5ec262
*** Flash config restore failed, using defaults ***
CONN led=0
SER led=14
Wifi init, mode=STA
262> espFsInit(0x4022c4c8) returned 0
266> Httpd init, conn=0x3fff4c00
269> pcb->localport 80
271> Serbridge pins: reset=12 isp=13
275> pcb->localport 23
277> ** esp-link ready
280> mode : sta(18:fe:34:fd:f8:a6)
283> add if0
285> f 0, scandone
1298> add 0
1298> aid 2
