- Thu Dec 03, 2015 8:08 am
#35572
Small issue
I just installed the v2.1 beta5 binaries on an ESP01 and I get no access point either, it says it is opening one but my iPad cannot find anything but my usual router.
Thought maybe was a it was a dodgy ESP so tried a second one with the same result.
The first one was running on a breadboard off 3.3v, which works fine nearly all the time, the second one was using an onboard 3.3v reg and has never had a problem.
I cant find any info on what to do if no access point ..
87> ** esp-link v2.1.beta5 - 2015-11-16 00:02:10 - 4e100b0
87> Flash config restore *FAILED*
88> CONN led=0
90> Wifi init, mode=AP+STA
93> Wifi uses DHCP, hostname=esp-link
96> "ip": "0.0.0.0"
99> "netmask": "0.0.0.0"
101> "gateway": "0.0.0.0"
104> "hostname": "esp-link"
107> sleep enable,type: 2
109> Httpd init, conn=0x3fff295c
113> Serbridge pins: reset=12 isp=13 swap=0
125> Reset cause: 0=normal
125> exccause=0 epc1=0x0 epc2=0x0 epc3=0x0 excvaddr=0x0 depc=0x0
126> Flash map 512KB:256/256, manuf 0xC8 chip 0x4013
130> ** esp-link ready
133> MQTT_Init
134> mode : sta(18:fe:34:a4:c6:47) + softAP(1a:fe:34:a4:c6:47)
140> add if0
142> add if1
143> dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
151> bcn 100
11452> chg_A3:-180
15109> Wifi check: mode=AP+STA status=0
15109> Enabling/continuing uart log
21752> chg_A3:0
30110> Wifi check: mode=AP+STA status=0
30110> Enabling/continuing uart log
32052> chg_A3:-180
42352> chg_A3:0
45110> Wifi check: mode=AP+STA status=0
45110> Enabling/continuing uart log
52652> chg_A3:-180
60110> Wifi check: mode=AP+STA status=0
60110> Enabling/continuing uart log
62952> chg_A3:0
73252> chg_A3:-180
75111> Wifi check: mode=AP+STA status=0
75111> Enabling/continuing uart log
83552> chg_A3:0
90111> Wifi check: mode=AP+STA status=0
90111> Enabling/continuing uart log
93852> chg_A3:-180
104152> chg_A3:0
105111> Wifi check: mode=AP+STA status=0
105111> Enabling/continuing uart log
Ok, googling the chg_A3:0 it appears the SDK for this version is busted ?
http://bbs.espressif.com/viewtopic.php?t=1310Reflashed with an older copy of esp-link 0.10.3 and that is working, AP straight away, though dropping a lot of characters off the serial with a quick test.. will do some more reading, I just have a micro in the shed I want to debug..
edit: nothing to do with esp-link, that worked great and i love it and will use it a lot !
It worked just fine .. telnetted to the shed and dumped about 20 minutes of data before the power supply in the prototype blew up
client has fitted a 12-0-12 when i specified a 9-0-9 so yeh .. transformer died when one of the filter caps blew out..
