WhiteHare wrote:I tried upgrading my Huzzah ESP8266 to Release 2.0.beta2 using ESP FLASH DOWNLOAD TOOL V2.3 (actually, it says v2.3 in the title bar when I open it, but the application file says its v2.4, so I'm guessing it's the most current?) with the settings given in the release instructions:
flash boot_v1.4(b1).bin from the official esp_iot_sdk_v1.3.0 and included in the release tgz to 0x00000
flash blank.bin from the official SDK and also included in the tgz to 0x3FE000
flash user1.bin to 0x01000
However, it does not appear as an AP that I can connect with, and I can't connect with it using its former IP address either. The blue LED on it double blinks once every 15 seconds. Not sure what that means, but probably something.
I used the same flash tool to upload the version 1.0.1 firmware without a problem. Does it no longer work for Release 2?
Edit: OK, I just tried Release 2.0.rc1. Same results.
It would seem my Adafruit Huzzah simply doesn't work with any of the Release 2 firmwares.
I've just flashed my Huzzah with version 2.2.b2 after some difficulties.
I have used ESP_DOWNLOAD_TOOL_V2.4 from Espressif. At first couple of tries neither version 2.1.7 nor 2.2.b2 booted up (as in: no AP was found and the LED on GPIO0 stayed dimmed like it does on bootloader mode). After googeling around I stumbled on your post so I tried it with version 1.0.0 which booted up and I could connect it to my network.
So, I decided to try v2.2.b2 one more time after getting a friendly headup on gitter by @tve, and miraculously I now have a working esp-link on y huzzah.
Now I just have to learn using it
EDIT: I spent some time to get AtmelStudio 7 directly talking to my 328p-pu projects, I ended up with a nice addon made by @bc547: https://gitlab.com/bc547-playground/avr-link, using it as an external tool. Before I used to use avrdude but the original version doesn't support net communication on windows.
Alternatively I've learned in the gitter about a modified avrdude for this but I'm not sure if I can link to that directly (also, I haven't tried that because I'm very satisfied with @bc547's avr-link.
