ESP8266 Webserver Project
Moderator: Sprite_tm
By mharizanov
#38528
ToSa wrote:I'm using 1.5 right now. Will recompile with 1.3 and report back if that solved the issues.
Curious if that worked for you or is it just me..
By Sprite_tm
#39472 If you have had trouble with the 1.5 SDK and captive portals, can you retry the latest Git branch? Seems something changed around 1.4/1.5 and I fixed it in the latest set of commits.
By mharizanov
#39480 @Sprite_tm latest git did the trick. Just removed a "to" suffix to espconn_send, not sure why you had it there.
remot_info *remInfo=NULL;
//Send data to port/ip it came from, not to the ip/port we listen on.
if (espconn_get_connection_info(conn, &remInfo, 0)==ESPCONN_OK) {
conn->proto.udp->remote_port=remInfo->remote_port;
memcpy(conn->proto.udp->remote_ip, remInfo->remote_ip, sizeof(remInfo->remote_ip));
espconn_sendto(conn, (uint8*)reply, rend-reply);
