I try to modify the cgiWiFiConnect to set static IP.
int ICACHE_FLASH_ATTR cgiWiFiConnect(HttpdConnData *connData) {
char essid[128];
char passwd[128];
static ETSTimer reassTimer;
if (connData->conn==NULL) {
//Connection aborted. Clean up.
return HTTPD_CGI_DONE;
httpdFindArg(connData->post->buff, "essid", essid, sizeof(essid));
httpdFindArg(connData->post->buff, "passwd", passwd, sizeof(passwd));
//wifi_set_opmode(STATION_MODE); // Force Station mode
wifi_station_dhcpc_stop();
//wifi_softap_dhcps_stop();
os_memset(&stconf, 0, sizeof(struct station_config));
os_strncpy((char*)stconf.ssid, essid, 32);
os_strncpy((char*)stconf.password, passwd, 64);
os_printf("Try to connect to AP %s pw %s\n", essid, passwd);
IP4_ADDR(&info.ip, 192, 168, 15, 10);
IP4_ADDR(&info.gw, 192, 168, 15, 1);
IP4_ADDR(&info.netmask, 255, 255, 255, 0);
wifi_set_ip_info(STATION_IF, &info);
//Schedule disconnect/connect
os_timer_disarm(&reassTimer);
os_timer_setfn(&reassTimer, reassTimerCb, NULL);
//Set to 0 if you want to disable the actual reconnecting bit
#ifdef DEMO_MODE
httpdRedirect(connData, "/wifi");
#else
os_timer_arm(&reassTimer, 500, 0);
httpdRedirect(connData, "connecting.html");
#endif
But the IP info seem not to be saved in flash so that when the esp8266 restart, dhcp is used to get the IP. If i try to disable the dhcp, the IP is wrong.
What am i missing here?
Any help would be greatly appreciate.
Thanks.
