ESP8266 Webserver Project
Moderator: Sprite_tm
By rith87
#46881 Hello folks,
The sample ESP-HTTPD mostly works for me but there are some corner cases that don't and I was wondering how folks out there dealt with this.
  • In the browser, if I typed in some HTTP address, the index page would show up most of the time but occasionally, I would receive an ERR_CONNECTION_RESET. And if I waited a while, the browser would refresh the esp8266.nonet page and then I would see them cats again. Has anyone fixed this intermittent problem?
  • However, if I typed in some HTTPS address, there would be no redirect to esp8266.nonet. Is there a fix for this as well?
I'm probably going to keep investigating but if anyone has any ideas, I'm all ears!
By rith87
#46886 Regarding the first problem, here's what I see with wireshark:
  • Phone sends GET request
  • ESP8266 responds with a 302 to esp8266.nonet
  • Some SYN/ACKs between phone and ESP8266
  • RST sent from ESP8266 to phone
  • And the above two steps repeat itself a few times
Any ideas why the ESP8266 is sending a RST?
By Sprite_tm
#46957 I can acknowledge this issue: I've seen it myself but have been too busy to spend any quality time trying to figure out what causes it. Just for my info: are you using the nonos or the FreeRTOS version?
By IOT@urremote.com
#47053
rith87 wrote:Hello folks,
I think you are stuck with this behaviour. Browsers do not redirect https addresses which I expect is a security issue so that you you can not be redirected from my.bank to scammer.bank.
