Sming - Open Source framework for high efficiency native ESP8266 development
By anakod
#17330 Hello piontec!
3), 5)
Memory management is fully equal standard C++ rules. One importnant thing is that Json lib doesn't copy strings to temporary memory:
https://github.com/anakod/Sming/issues/59
So original string reference should be available all time during processing.
Next, you have a small bug in this line:
Code: Select allBssInfo bss = scanResult->elementAt(i);
It doesn't saved as reference (only local on stack copy of object), so memory will be corupted. Please try BssInfo &bss = .... It should solve problem (but only on last version previous version doesn't love String and requrie const char* vars only)
Another great example is last added network configuration example. It should cover many standard configuration cases and also will show how to use Json lib.
By esp03madness
#17424 Hello friends, just seeing this thread for the first time. I looked around a little, the project looks good and I have a couple of questions:
1. What is the difference between Sming and using the Espressif SDK directly? What exactly is abstracted?
2. What about debugging? Am I correct to assume that only print statements are available?
By piontec
#17461
Markus Gritsch wrote:Read theese two excellent comments, they helped me to understand it a bit better:
http://tech.scargill.net/memory-use-esp ... mment-1213
http://tech.scargill.net/memory-use-esp ... mment-1214
And yes the Sming linker script is modified so that all function go per default into flash and not consume IRAM.
Thanks, that really explains a lot! Does anybody have something like that about slot 0/1 firmware layout an related issues with OTA? Is Sming with bootloader also using doube firmware slots? Because I think I saw, that max size of spiffs image is a little over 200kB, so is there still a space for double firmware and double spiffs image in 512kB flash? Or is the spiffs image shared somehow for both slot0 and slot1 firmwares?
