Sming - Open Source framework for high efficiency native ESP8266 development
By alonewolfx2
#25546
Wiwat Arun wrote:I tried every pins one by one to make sure that I did not connect to the wrong pin.
Currently I connect D4(GPIO 2 for NodeMCU v2) -> R 500 ohm -> LED -> Ground.
Is that correct ?
no. because gpio2 is special pin . if led pulling down that pin , your module cant boot. can you try gpio2 to 3.3v with 500ohm resistor and led on gpio4 or 5?
