Currently I connect D4(GPIO 2 for NodeMCU v2) -> R 500 ohm -> LED -> Ground.
Is that correct ?
Explore... Chat... Share...
Wiwat Arun wrote:I tried every pins one by one to make sure that I did not connect to the wrong pin.
Is that correct ?
