Sming - Open Source framework for high efficiency native ESP8266 development
By emogg
#29976 esp-12 4MByte, esp-open-sdk 1.3, latest Sming feature/rboot, Linux
As there's no handshake I suppose there's a full tx buffer somewhere that's hanging the boot up, but where and why? Nothing happens until I connect my usb serial device to the esp-12
Any ideas anyone?
By LievenMerckx
#29980 difficult to answer, since your physical wiring is not clear. Saw a similar behaviour with the nodeMcu boards however. It's not because you ended writing into the flash memory that the program starts executing.
You need to pull down the reset pin, for nodemcu I do this through a small program on linux that lowers RTS serial out during 1 second.
