Sming - Open Source framework for high efficiency native ESP8266 development
By Venkatesh
#34739 Till you setup SMING_HOME and ESP_HOME to correct path the compilation won't work.
If you have built esp-open-sdk in some other folder other than '/opt/esp-open-sdk', then set the path in ESP_HOME
The SMING_HOME should be folder of Sming + Sming, i.e if your sming files are in /opt/Sming, then SMING_HOME should be '/opt/Sming/Sming'
