Sming - Open Source framework for high efficiency native ESP8266 development
By fastlink30
#39499 i need to register some commands with the commandHandler.registerCommand(), and execute them passing only the string containing the commandline, not need to parse tcp/stream (looked on the sming source).
insert command is quite simple with commandHandler.registerCommand()
i think i must use the CommandExecutor.processCommandLine(stringcommand), but not understood how to initialize/how to use
also i not want CommandExecutor load the system default command automatically, and no standard prompt (Sming>) is possible disable this?
there are examples?
thanks
By hreintke
#39525 No need to call commandExecutor or processcommand yourself.
If you register a command your callback function will be called by the framework.
You can see the example in the CommandProcessing_Debug example
