Json exception
Posted: Sun Jan 24, 2016 2:27 pm
with this routine i print some info on serial, but when quit routine, get errors (as you can see on image attached)
the network object must be 'closed'? how is correct?
void inforeadCommand(void)
DynamicJsonBuffer jsonBuffer;
JsonObject& network = jsonBuffer.createObject();
network["HEAP"] = system_get_free_heap_size();
network["IP"] = WifiStation.getIP().toString().c_str();
network["MASK"] = WifiStation.getNetworkMask().toString().c_str();
network["GWAY"] = WifiStation.getNetworkGateway().toString().c_str();
network["DHCP"] = WifiStation.isEnabledDHCP();
network["SSID"] = WifiStation.getSSID().c_str();
network["PASS"] = WifiStation.getPassword().c_str();
network["UDP"] = UDP_PORT_SERIALE;
network["CHAN"] = wifi_get_channel();
network["CHIP_ID"] = system_get_chip_id();
network["SDK"] = system_get_sdk_version();
network["VDD"] = system_get_vdd33();
network["CPU_FREQ"] = system_get_cpu_freq();
network["HOSTNAME"] = wifi_station_get_hostname();
Serial.printf("%s\r\n",network.toJsonString().c_str());
another think, how to calculate vdd from the int returned from system_get_vdd33()?
thanks
thanks
