https://github.com/tuanpmt/esp_mqtt
Can SMING's MQTT library support secure MQTT using SSL? If not, is it hard to add the above library to SMING?
Explore... Chat... Share...
helpme wrote:This MQTT library used by ESP8266 supports SSL.
alonewolfx2 wrote:almost. please test this repo link. and if you have any issue please let us know on gitter and here.
https://github.com/slaff/Sming/tree/feature/axtls-devhelpme wrote:This MQTT library used by ESP8266 supports SSL.
